What does this light mean? long hood
Low on oil?
Isn’t it the park brake?
Double duty light...parking break and voltage...check voltage with a multimeter. Could be an alternator problem...hard to tell at low RPM tho...
Warning...it's been a long spell without a longhood and relying on a fading memory.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 04-01-2021 at 12:18 AM.. |
Parking brake? That's interesting. I never knew that there's a light hooked up to it. It comes on periodically through out my drive today. This is my second drive. Took it to get it aligned today, on my way back, I noticed it. I don't have a parking brake, Wipers and such. Its been taken out for weight savings. If I am to drive this on the street more often (looks that way for now), it must be re-installed.
Alternator? Thanks, keep em' coming. |
What's the light for next to the key down below? I have never seen it lid up. I have had this car for 9 months but have not had a chance to monkey with it.
hazard or 4-way flasher
The B should indicate low brake fluid. The G should indicate low voltage.
The top light I think on my '70 914-6 is a green colored light that indicates low oil pressure. But I'd have to go check it.
Bland
Also that R tach is crooked, you need to straighten it...
Hoodlums!
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Data Farmer
The switch below the hazard button on the dash. That's the NOS button, right?
My other ride is a C-130J
In my ‘75 it indicates handbrake is on. The “G” light below is low voltage.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Sounds like I gotta find those wires for the hand brake.
Weird - I thought it was a double duty Parking Brake and Charging Light.
David 1972 911T/S MFI Survivor |
Also a factor is that Porsche used different standard gauge set ups depending on the model, although "S" gauges were an option for T's and E's...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Charging light? From alternator? It comes on and of as I drive, sometimes glowing bright red, sometimes its just dimly lit most times, its off.
Also, looks like an aftermarket or altered tach to me...goes beyond the revs range of an original T, E, or S. S had the highest redline at 7,300.
Data Farmer
I googled 1969/1970 porsche 911 owners manual pdf, you might try for your specific year.
Manual page 17/ pdf page 14 http://content.us.porsche-clubs.porsche.com/PorscheClubs/klassieke-porsche-911-en-912-club/files/Porsche911T1969_1970USownersmanual.pdf Last edited by LEAKYSEALS951; 04-01-2021 at 11:23 AM.. |
Senior Member
on my SC that is the green light of death..... If it comes on while driving - shut down and check fan belt
78 Euro 911sc Targa 03 Hayden SCWDP |
^ OK, so that is just like my 914-6, which has a "T" motor in it.
But the OP's setup looks different. |
Its a 10,000 rpm tach. Newly rebuilt along with the speedo.
