What does this light mean? long hood
Low on oil?
Old 03-31-2021, 11:59 PM
Isn’t it the park brake?
Old 04-01-2021, 12:13 AM
pwd72s's Avatar
Double duty light...parking break and voltage...check voltage with a multimeter. Could be an alternator problem...hard to tell at low RPM tho...
Warning...it's been a long spell without a longhood and relying on a fading memory.
Old 04-01-2021, 12:16 AM
Parking brake? That's interesting. I never knew that there's a light hooked up to it. It comes on periodically through out my drive today. This is my second drive. Took it to get it aligned today, on my way back, I noticed it. I don't have a parking brake, Wipers and such. Its been taken out for weight savings. If I am to drive this on the street more often (looks that way for now), it must be re-installed.
Alternator?
Thanks, keep em' coming.
Old 04-01-2021, 12:29 AM
What's the light for next to the key down below? I have never seen it lid up. I have had this car for 9 months but have not had a chance to monkey with it.
Old 04-01-2021, 12:31 AM
hazard or 4-way flasher
Old 04-01-2021, 01:10 AM
The B should indicate low brake fluid. The G should indicate low voltage.
Old 04-01-2021, 01:11 AM
The top light I think on my '70 914-6 is a green colored light that indicates low oil pressure. But I'd have to go check it.
Old 04-01-2021, 01:15 AM
Bland
unclebilly's Avatar
Also that R tach is crooked, you need to straighten it...
Hoodlums!
Old 04-01-2021, 01:16 AM
Data Farmer
The switch below the hazard button on the dash. That's the NOS button, right?
Old 04-01-2021, 04:09 AM
My other ride is a C-130J
RNajarian's Avatar
In my ‘75 it indicates handbrake is on. The “G” light below is low voltage.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-01-2021, 04:40 AM
Sounds like I gotta find those wires for the hand brake.
Old 04-01-2021, 10:59 AM
Weird - I thought it was a double duty Parking Brake and Charging Light.
1972 911T/S MFI Survivor
Old 04-01-2021, 11:05 AM
pwd72s's Avatar
Thinking about it, you're probably right...I recall the alternator warning light flickering at a low brightness level with the car idling. Just no longer sure of the location. Generally, loved the gauges on my old 911S other than wishing Porsche had somehow installed a volts gauge.
Also a factor is that Porsche used different standard gauge set ups depending on the model, although "S" gauges were an option for T's and E's...
Old 04-01-2021, 11:11 AM
Charging light? From alternator? It comes on and of as I drive, sometimes glowing bright red, sometimes its just dimly lit most times, its off.
Old 04-01-2021, 11:13 AM
pwd72s's Avatar
Also, looks like an aftermarket or altered tach to me...goes beyond the revs range of an original T, E, or S. S had the highest redline at 7,300.
Old 04-01-2021, 11:16 AM
Data Farmer
I googled 1969/1970 porsche 911 owners manual pdf, you might try for your specific year.
Manual page 17/ pdf page 14
http://content.us.porsche-clubs.porsche.com/PorscheClubs/klassieke-porsche-911-en-912-club/files/Porsche911T1969_1970USownersmanual.pdf
Senior Member
on my SC that is the green light of death..... If it comes on while driving - shut down and check fan belt
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 04-01-2021, 11:23 AM
^ OK, so that is just like my 914-6, which has a "T" motor in it.
But the OP's setup looks different.
Old 04-01-2021, 11:27 AM
Its a 10,000 rpm tach. Newly rebuilt along with the speedo.
Old 04-01-2021, 11:29 AM
