They are original Bosch parts. Probably too late for you but this may serve others here. |
Was supposed to be going away but the weather is miserable so decided to do a bit more on the car instead.
Tried to measure all 3 sensors resistance and weirdly none of them would register anything when trying all combinations across 3 terminals as outlined in the Bentley, it seems that every circuit is broken on all 3 In the Bentley the testing for the CHT sensor shows 2 pins whereas mine only has 1 so guessing they have the updated 964 upgrade that I will also do And yes my multimeter is working correctly as I tested it on a couple of other things including number 1 injector and it measured correctly I have taken them all out which was surprisingly easy and only took 30 minutes Is there an alternative part to the CHT sensor |
2. On ref & RPM sensors, there're three wires for each (one is a shield). Only one of the three connection combinations should indicate a resistance measurement. 3. It's unlikely that all three sensors are bad.
Dave |
Anyway I had another look and got the correct reading on the reference sensor after cleaning the terminals a bit but the CHT and speed are completely dead Last edited by Paul Shepherd; 09-03-2022 at 02:40 AM.. |
Dave |
Is RPM a typo? Last edited by Paul Shepherd; 09-03-2022 at 06:16 PM.. |
Yes.
No. Actually, using RPM (engine speed) is the more correct indication of what the DME ECM is looking for, and not speed which typically relates to MPH.
Dave |
Thanks for your help all 3 sensors have been ordered
Diss Member
Instead of the "Replace the reference sensors just to see" it makes much more sense to test them. (Always test, test, test instead of replace, replace, replace!)
You can get a very basic oscilloscope for dirt cheap now. When cranking you should see a 2.5v signal on the reference sensors. Obviously one is multiple signals per revolution and the other is once per rotation.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I did test them and 2 are not in spec |
If issues with multiple sensors then check earth strap. In fact check it anyway. My money's on crank position sensor cable.
Sent from my SM-G988B using Tapatalk |
He said it was OK in post #24.
Dave |
When mine failed, I grounded my DME connector to the intake manifold and drove 9 hours home without issue. It was a ***** to cold start though.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Just an update
Installed my 3 new sensors today reference, speed and CHT, a pretty easy job took less than an hour which was nice. Turned her over and she started straight away so very happy Thanks to everyone for their help |
Based on trends we've been seeing, replacing these three sensors are right up there with replacing the fuel lines and having the injectors serviced on every 3.2 still running original gear.
I had replaced mine 12 or so years ago. when I got a no start issue. Then a few year back my car acted like it was haunted. The idle would go up and down at random up to 2,500 RPM. Then die, hard to restart and very little power. It did that right at the very busiest intersection in my town. I got home and replaced them. They would test out fine when cold. Once they were hot, they would fail, then be ok, then fail.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
All original marked 86 looked like new in the car but couldn’t believe how stiff they were and there were small cracks starting to develop on the inner layer Maybe I need to look at the injectors in the near future, do they fail or is it a performance thing |
You'd be surprised how poorly they work at this point. I had a flat spot in the power band that was resolved after having them cleaned. They can also leak into your cylinders while the car is off.
Good to hear you got it sorted.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
This is the injector service I've been using.
