Subscribed
Can we get a video of the engine running?
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Building a 3.0 9 bolt engine now, and switching to a 718 S VGT turbo which MoTec will control.
should be interesting! If I can make the same power with 600-1000rpm faster spool it will be amazing. I'm making support parts for these amazing turbos, and may even make a stand alone controller for the VGT. Big updates will be coming later this year
North Idaho CDA / Spokane area Instagram: to.performance MoTeC USA Authorized Dealer Porsche 959 Department Manager at Canepa *retired after 10 years* Website / Webstore https://www.topperformancetuning.com/ |
Registered Minimalist
did the 2.7 go kablooey? but seriously, interesting work and looking forward to the updates
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
![]() I'll be rebuilding / restoring the 2.7 and probably sell it with my full MoTec NA ITB package, or use it in my other 911 chassis (1980 Carrera) Was thinking about building a super lightweight NA car, so the mag block is an advantage there.
Rosco_NZ
Wow! What do you make of this Henry Schmidt?
Bland
Awesome build. It will be very interesting to see how the mag case and stud threads survive this.
I was heavily criticized for building my 2.7 in my (then) track car with a stock 2.7 bottom end by a factory trained Porsche tech. 15 years later still going strong.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
So awesome of you to share the timing table and other details! I'm building a 3.2 turbo and this is amazing info.
Two questions: - What is your compression ratio? Stock? - Are you running twin plug or single? Thank you! |
Single plug - There doesn't seem to be a significant advantage to run twin plug with coil on plug ignition. I've messed with this on the dyno, where I can turn the lower coils off just in the software. Basically no difference. Might help with a really high power turbo engine running e85 or e98 fuels?
Very impressive, and informative for those contemplating going down this road in the future, I suspect many here will be grateful to you for sharing your knowledge and experience on this, awesome!
![]() Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Interesting on the single plug vs twin. Most folks seem to insist twin plug is mandatory but I'm also considering staying single plug when I rebuild my 3.0 to 3.5 turbo..
Always learning. www.aircooledporsches.com.au |
PCA Member since 1988
Yes, great info on the single vs. dual plug power. When Henry finishes his special project engine, with the welded peanut-shaped twin plug combustion chambers, I hope he will do the same.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Only needed 22 deg ignition at 100KPA above 3000RPM? That made best power? I would have expected more timing would be needed but maybe the 2.7 small piston really helps here.
Nice work!
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
As the bore size increases twin plug may help more.
The small bore size of the 2.7 may be why twin plug has less benefit? Also under boost flame front speed increases, densely packed air/fuel will propagate flame front much quicker. A bore size > 100mm will likely benefit from twin plugs.
I usually shoot for 90-95% of available power with a safety margin that's double what it would be at 100% power. Unless you are running EGT and O2 sensors on every cylinder, with individual cylinder corrections, this a much better point of tune. BTW - I have done this on a few engines! Flat six air cooled engines seem to need a bit of extra fuel and a bit less timing on cylinders 2 and 5, which makes perfect sense.
