Off Topic, but air cooled
OK, so the other car, when I want to take more than one other person with me and need a back seat, is a 65 Corvair Turbo Convertible. Unfortunately, the Carter Work of the Devil Side Draft Carburetor has been kicking my butt lately, and I'm wondering if someone here might be able to help or point me in the right direction.
It was working fine one day. As part of my "standard maintenance", I replaced Coil, Points, Plugs, Condenser, Cap and Rotor. The only real problem I was having at the time was that I was running hot on the freeway. (constant 3,000 RPM in 85+ degree temps and 20 to 30 miles later, the buzzer would be sounding. I don't know if the gauge is accurate, but the buzzer gets your attention). I've been told that "overlean" could cause heat, but I've since noticed that the PO used an Otto variable fan at 1.32 to 1. I've reduced it to 1.40 to 1 to see if that will make a difference. If it does, I'll find a stock (1.56 to 1) sized fan. I opchecked my tune up, and it ran great. The next day, it would not start, and the carb would leak gas by the pint after grinding 5 to 10 seconds. After many conversations with Ray Sedman of American Pi, I ordered a rebuild kit from the Source. Spent an entire Saturday on it, re-installed it on Sunday with a Source electronic choke. During the rebuild, I found a leaking float. I spent several tries before I was able to get the float re-soldered, but I finally got it. Everything ran great for fifty miles, and then it stalled. No start, plus gas leaking from the carb. On a hunch, I pulled off the float bowl cover. Sure enough, the float was leaking again. Ordered an NOS float. Looked for a NOS carb, but came up empty. The float and gasket came from Glen Wolf. I also found a Weber manifold if I want to convert to a side draft Weber 2 bbl. Waited a week for the new float. Adjusted the shut off to 3/4", and the drop to 2 3/8 in at the bottom of the float. Installed with new gasket. It was a bit hard starting, but it started. I could not adjust the idle below 2,000 RPM, and more frequently than not, it was running at 2600 RPM. The choke was opening/closing correctly. Began looking for vacuum leaks. The screws in the choke housing were stripped. I used JB Weld and then re-tapped them, as no one in town has an 8/32 helicoil kit. I checked the stacked gaskets on the throttle plate to ensure that they were aligned correctly and that there were no blocked passages. I adjusted the throttle plate to be sure that when closed, there was a .032 gap on the bottom of the throat. The spec is .033, but my feeler gauge set has only a .032 and a .034. It was difficult to measure, because the gauge is flat and the throat is circular, but I got as close as I could. I used a new gasket between the carb and the turbo. I did not remove the float bowl cover. I got the carb body to throttle plate screws as tight as I could. The throttle plate was checked for warping, and was OK, the carb body was slightly warped. Stacked gaskets measure 7mm (.31 inches) before istallation, and 6mm (.26 inches) installed (Mr. Sedman's recomended numbers) I would guess the warpage on the body could be ground out, but that's a last resort if I still have a vacuum leak. I re-installed the carb. The car will not start. I did not check for spark, but I did hook up a timing light, and the light is firing as it cranks. After cranking for about forty seconds (no more than ten seconds at a time), I get one or two drops from the carb. No where near like the flood I had before I replaced the float. I did hand jam the throttle open and closed, which eventually squirted a little extra fuel into the carb, but while the starter turns the car, it will not fire. One thing I did think of is that the last time I turned it off, there was a loud backfire, so while it's possible the muffler was damaged, I did fell air pushing out from the muffler as someone else was cranking. At this point, I am officially baffled and am hoping someone here has an idea. I am now seriously looking for someone who knows side-draft carbs in the New Orleans area. I am going out of town on Friday for three weeks. If I can't fix it this week, I will have to ship the car to Maryland in November, and if I can't get it to start then, I will incurr additional shipping charges. I will NOT drive it from NOLA to MD in November because I don't trust it. As a "By the way", Ray at American Pi does not have a rebuilt in stock, and said that he has a month + wait on carb rebuilds. Courses of action at this point include finding a YH guru in NOLA, selling the car (difficult when it's not running), finding a Weber and continuing to tinker with at least a carb that is well documented, and placing a thermite grenade on the engine cover and pulling the pin. COA #1 would be the most satisfying, but #4 is looking better and better... Anyone have any other ideas? |
Could you repeat that?
944 TURBO!!!! 1982 911 SC Targa (loved but sold!) 2005 Cobalt SS (0-60 in 6.1!!) 2003 BMW 325i ex got in divorce 1969 912 Coupe (sold) PCA Member |
Senior Member
Basically Don needs to know if there are any side draft pros in the N'Orleans area and if there might be a more modern setup for his needs.
Neat car -- I used to race one with Ralph Nadar strapped to the hood. Do the convertibles still fill the rear footwells with water? John
'78 Targa in Minerva Blue |
Don,
Have you tried posting here?...... http://php.corvaircentral.com/cgi-bin/bbs/YaBB.pl?board=mech Good luck and let us know what happens. BTW, wonder if John Walker would know. I bet he does.
Warren & Ron, may you rest in Peace. |
Stahlwerks.com
I've seen some side draft carbs on ebay, not sure of condition, I've been looking for vertical units. Webers and delorto's.
Don't know if that helps or not. After the rebuild, are the bowls filling up? What happens if you squirt fuel straight down the carb? Does it fire at all then?
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
I read there every day. Also, www.corvaircenter/forums. No one really came up with anything, except for the people who said to check ignition (hence the comment about new ignition, above).
I've seen gas sitting in the carb. I may hit it with ether tonight... we'll see. If anyone can figure anything else out, I'd appreciate it. Z PS: Yes, the bowls are filling. The original problem was that the float would sink and overfill the bowl. I do have good pressure going to the carb now, and the bowl is full and gas is sitting in the bowl. I am wondering if I didn't tip it sideways or something and dis-lodge something which is now blocking a path somewhere....
We keep you alive to serve the ship. Row well and live. Last edited by Don Z.; 09-30-2003 at 01:00 PM.. |
Don
My Corvair experience is non-turbo but ... Warren LeVeque, who is great with Corvairs might be a good person to talk to if you have not already. If you need his email address I can get that. I sold off all of my YH carbs but I would venture to guess the body may be warped or what about to much fuel pressure? I run an electric fuel pump from The Source and have a pressure regulator on it to be safe. Your problem may be fuel pump related. Have you checked the pump? What is the condition of the fuel tank? It is also possible there is a lot of dirt in the system. Now if you decide to sell the car let me know. I would hate to see the demise of another little air cooled wonder.
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
You do not have permissi
If the engine had been running very rich, the first thing I'd do is change the plugs(not champion), and check for spark.
If the engine starts and dies after dribbling gas into the intake, it would definitly be a fuel delivery problem. Another thought might be sticking metering valves-some taps on the side might free them up. Last edited by john70t; 09-30-2003 at 05:02 PM.. |
