SCWDP911's Avatar
Man, she is cleaning up rather nice isn't she. Good for you coming across her... and good for you to be one to enjoy her for what she is.
Shane
- 1984 928S
Old 02-25-2008, 11:10 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Originally Posted by berettafan View Post
Absolutely not! That's 914 talk Jgordin
Strip that b!tch to the bare bones and be thorough about it! I say this BECAUSE it's a car worth saving.
Thinking about the rear torsion bar tube, rockers, floors that might have all that nasty water holding horsehair stuff, little cubbies in the front pan area, you name it there are places for water to hide and do nasty things!
+1 Worth spending the $ to do it right. Would be sad to see it rot away...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-25-2008, 11:11 AM
Water from Katrina
If this car was in Slidell and only had water for a short period of time it was storm surge. The storm surge north of Lake Pontchartrain was pretty much fresh water storm runoff that got pushed back on shore for an hour or two. It would be like running your car through a car wash with the windows down. It's a pain, but not catastrophic. Cars on the Southshore were exposed to salt water and toxic substances in some areas. The way to tell in addition to looking at the body is to look at the magnesium parts, and to a lesser extent, the aluminum parts. Outboard motors retrieved from the Southshore are crusty. Porsche's and VW's, look at the engine and transmission cases. As many of you know, once the magnesium is exposed to salt water, it starts to disintegrate rather quickly. This car, two years + out from the storm is virtually unscathed.
Old 02-25-2008, 11:27 AM
pryord's Avatar
Here's my plan for seeing if she runs:
Remove plugs and rotate engine, to make sure everything feels right.
New plugs, fuel filter and fan belt.
Change transmission fluid and oil.
Purge gas tank and have professionally cleaned.
Disconnect fuel lines and run fuel through via fuel pump to purge gas/water.
Reconnect fuel lines and pressurize system, checking for leaks.
Turn the key!
What else should I be thinking about?
I want to try starting the engine to see what sort of shape it's in. I know I have many, many more projects fo this car. However, I like the suggestion of "reconditioning" over "restoration". Of course, I'll repair/replace anything that needs it over time. The car has so many things going for it, I want to salvage as much of the original equipment as possible. To be honest, I'll probably achieve long term restoration via many, many short term reconditionings.
1967 S
Old 02-25-2008, 12:24 PM
Selling it to me!
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 02-25-2008, 12:48 PM
Carbon Emitter
jkarolyi's Avatar
=JAs many of you know, once the magnesium is exposed to salt water, it starts to disintegrate rather quickly. This car, two years + out from the storm is virtually unscathed.
I wouldn't assume this. First of all, the '67 911S has an aluminum case and transmission. As I said before, there are LOTS of hidden areas in 911s that you can't see that trap water, clean or not.
If it were MY car I would take steps to take care of this, but David doesn't appear concerned about the potential monster that lurks beneath the pretty paint, so this discussion is moot anyway.
Old 02-25-2008, 02:02 PM
pryord's Avatar
Jay is right, I'm not concerned. Having owned several pre-galvanized cars, I know there must be rust issues with the '67. The car isn't going to turn into a pile of rust powder overnight while sitting in my garage. I'll eventually get through all the projects, including a full strip down of the body and rust repair/repaint one day. For me, these projects will happen faster if I get to drive the car and be inspired along the way. If I do some more exploration and find the car isn't safe to drive, I'll take a step back a reevaluate.
Years ago, I completely dismantled and stripped my SC down to bare metal, primed, block sanded, etc. I know the danger of taking on big projects and getting overwhelmed. I want to take my time and do things right. Since it is my car, that's the way I'll approach it.
The great thing is that this car is certainly worth all the thought, time and effort.
1967 S
Old 02-25-2008, 02:29 PM
Lundy
Kirk Lundmark's Avatar
Wow! What a find and how nice of the other couple. Porsche people are sure different. All they wanted was a loving home. Kind of like giving up the family pooch.
1982 911SC
98 Malibu Response
Lightspeed Solano Titanium
Old 02-25-2008, 03:06 PM
great car and find, david. best of luck! it looks really awesome. i wish i was lucky as you.
Old 02-25-2008, 03:10 PM
Carbon Emitter
jkarolyi's Avatar
Originally Posted by RatBox View Post
there's not a place on the body or interior ( that if not dry already ) will not air dry.
and especially with fans.
most people worry too much.
Worry....pffffft....what do I know, I've only owned 17 longhood 911s over the past 20 years.
Check out the thread I linked to on the first page and educate yourself.
I'm no white glove restorer...just want this survivor to continue surviving.
Old 02-27-2008, 08:42 AM
(the shotguns)
berettafan's Avatar
Hoy! Stripping it down to the bare bones and evauluating/correcting rust issues CAN and may very well be consistant with reconditioning.
Old 02-27-2008, 10:11 AM
AutoBahned
RWebb's Avatar
I don't know if the hidden areas that techweenie posted the great pics of (referenced by jkarolyi on p.1) are the same ones that Grady has posted about, but they will definitely require investigation.
I would wait until summer - it's dry then for one thing, and a lot warmer too -- then, I'd drill the holes, and stick hollow tubes up into the areas, connecting them to shop-vac or a hair dryer, or heat gun. I'd let each one run for a day or two.
Then I'd try to spray something up in there - rust remover or similar. Finally, primer, paint, and wax (got Tectyl?). Then plug the hole up before the rains start up again.
If you can get an illuminated borescope up in there, you'd be in great shape...
I should probably do that on my '73 too....
Old 02-27-2008, 11:55 AM
pryord's Avatar
I replaced all the fuel lines, drained the tank, replaced plugs and oil, got a new battery and gave her a crank. With each rotation the engine turned easier until... with a couple blasts of flame from the carbs... it caught and ran!!! ..and it sounds great. I'm totally shocked.
I've got some issues to sort out before driving it, but the engine sounds spectacular. It needs to calipers rebuilt, new shift bushings and perhaps I'll have the alternator rebuilt.
Some of you asked about the color. It's Burgundy Red (30868), a special order color for '67. I've got a video of the car starting, as well as my shocked expression. I'll figure out how to post it soon.
1967 S
Old 03-03-2008, 09:11 PM
AutoBahned
RWebb's Avatar
outstanding!
Old 03-03-2008, 09:13 PM
UnRegistered User
billybek's Avatar
Man, you have to be happy with that!!!
Bill K.
Old 03-04-2008, 05:15 AM
DeutschMark's Avatar
After you get everything cleaned out, you may want to give this a try to prevent or slow down further rust.
http://www.ddk-online.com/phpBB2/viewtopic.php?t=12954
95 540i/6
89 R100RS
Old 03-04-2008, 05:27 AM
SCWDP911's Avatar
That is awesome! This is almost shaping into another Hester thread. Can't wait to see the video.
Shane
- 1984 928S
Old 03-04-2008, 05:33 AM
pryord's Avatar
DeutschMark, thanks for the great link. There have been several very helpful links posted here. Sounds like I have some "drilling and filling" cut out for me. As mentioned by many of you, I need to make sure it's fully dried out first. I've made some test drills and found no water yet, but I have a ways to go.
Strangely, parts seem to come off this car easier than my SC. If I hadn't been told, I never would have known about the water damage.
When the engine ran, the oil pressure gauge was on the mark, but the oil pressure light was on. Do the gauge and light use different sending units? Where are they?
1967 S
Old 03-04-2008, 06:49 AM
Pete000's Avatar
Nice to see people winning the lotto !
Work to Live, don't live to work...
Old 03-04-2008, 08:12 AM
cassidyp's Avatar
David, Great car and it sounds like it is in the right spot too. On the oil light being lit, was the emergency brake on at the time?
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 03-04-2008, 06:08 PM
