racer_X's Avatar
So that is how the Japanese automakers make those engines- they use little people (note the vertical ladder into the crank "house"ing.
Wonder what the clearances on those parts are .5in?
Actually- how much diesel shake does that thing have? That will more than rattle your teeth!
John
1977 911S
Old 01-10-2010, 07:00 PM
Michael - 69E's Avatar
Crappy engine
Used to work on the 12 cylinder engines for a few years. Sure did pull some pistons and liners on those
Furthermore, everything on these engines is so big - you even need a crane to move tools around. The weight of a cylinder liner is 9060 kg
B&W RULES
Even though these are big engines, we still have an additional electrical shaft motor of a measly 9 MW to boost power if/when needed - the single propeller is simply too big
Full speed would set you back some 280 metric tonnes of heavy fuel oil / 24 hours.
My current ship's total fuel capacity is just over 14.000 metric tonnes
Michael
Blut Orange 911 E, 1969
Indisch Rot 911 Carrera 3,0, 1977
Alfa Rosso Alfa Romeo GT Veloce, 1967 (SOLD )
Old 01-11-2010, 01:11 AM
I'll race for food
gostraight's Avatar
yeap...had one in my SC. Did not handle for $#&%! went back to the 3.0
Radu
'82 SC black on black "The Beauty"
3.8 RSR GT2 track/street "The Beast"
www.octanegallery.com
Old 01-11-2010, 02:25 AM
david dolan's Avatar
"Even at its most efficient power setting, the big 14 consumes 1,660 gallons
of heavy fuel oil per hour."
Kinda makes a mockery of the environmentalists wanting us to take a car free day doesn't it?
David Dolan
1995 993 Carrera 4 India Red
1979 911 SC Targa Metallic Black
Old 01-11-2010, 02:51 AM
Kantry Member
oldE's Avatar
Two things:
I suspect with the right adapter plate, you could bolt it up...and the car would rotate at the end of the crank.
I can't believe no one has comment on the heresy of putting a diesel engine in an old Porsche. Heck, Jake & I have been tossing that idea around for a couple of years and have been afraid we'd be crucified here for the mention.
Yeah, I know..It's Wayne's idea so it's OK.
Good one
Les
Best
Les
Old 01-11-2010, 03:22 AM
tharbert's Avatar
Wyane forgot one spec:
MFI injectors the size of fire hose nozzles!
Old 01-11-2010, 04:58 AM
gearhead
Good one
Les
It's been done. There's more than a couple of VW TDI engines installed in 914s.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-11-2010, 05:55 AM
Sportomatic 4 the People
crater64's Avatar
Nah. That thing's screaming to be dropped into an E39 BMW.
1970 911T Sporto coupe
2016 E350 4Matic Sport wagon
Old 01-11-2010, 06:14 AM
Moto Meister can do your repairs!
'74 Metallic Salmon 2.7L more like 3.0L after rebuild. All Updates!
Old 01-11-2010, 09:07 AM
Can the moderator move this to the "rice" thread?
thanks,
Sherwood
Old 01-11-2010, 11:16 AM
Testing Dyno
This is the engine dynamometer to test those engines.
Old 01-11-2010, 02:03 PM
Liam O's Avatar
Make sure you raise the rear of the car as high as possible and dont forget to remove the rear bumper when offering it up.
1984 3.2 cab india red
1970 1192 Volkswagen Beetle
Old 01-11-2010, 02:21 PM
Former Options Trader !!!
With 5.6 million ft lbs of torque I would probably try and slip some 16 x 9’s under the rear to make sure all that power is put to good use. I am sure a nice sturdy 915 box can handle that with too m much trouble.
As someone else mentioned already I would love to know what the tolerances are like in that thing. From our perspective you’d think you might drive a 911 through some of those tolerances.
Seeing those guys working on the thing makes me think of pouring concrete on a bridge project. If one of those workers fell in as they were putting the thing together do they just keep going? Would anyone miss him until the shift was over?
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 01-11-2010, 03:21 PM
razordug's Avatar
Wayne,
I bet you can squeeze it in......
Oh.... you'll need a new garage.
Here's one......I know it's a pre-fab, but has a removable roof!!!!
Jay Flatt
1973 911 E Targa
1996 Chevy Tahoe
1978 Gibson Les Paul Standard
1977 Marshall
wannabee wannabee
WIL84911's Avatar
Nice catch! We might as well start cutting for our 24 in exhaust tips!
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 01-11-2010, 03:24 PM
Two questions on the dyno... I have no yard stick to even give any number it might read any relevance in my life.
1) If it comes in a little light in the numbers where do you even start to look?
2) What kind of minimum numbers do they guarantee? So I assume if it’s a couple hundred light they would never notice what about 10k or so ft/lbs of torque light, who would notice?
Old 01-11-2010, 03:25 PM
Some tolerances:
Big bearings are typically: 0,40 - 0,65 mm
Wear in piston ring grooves: Max. 1,0 mm on overhauled pistons with additional chrome layer.
These figures are for B&W 12K90MC engines (900 mm bore). The Sulzer tolerances are in same range.
Here is that big prop (9 metres diameter):
- and some turbocharger work:
Michael
Old 01-11-2010, 11:28 PM
tuned6's Avatar
Castrol 20-50? But what is the capacity? I have the feeling that with the staircase in the lower cylinder bore that a run to the local auto store won't do. And I thought that the case it takes to change the 911 engine was insane!
Old 01-12-2010, 04:52 AM
cfc cfc is offline
Good Fun
Now this is an interesting and fun thread. My dad is a steam engineer and worked in electrical power plants. The steam turbines had an oil tank that held approx 600 gal. and the steam turbine used high pressure oil pumps that lifted the turbine shaft off the bearings at start up.
Old 01-12-2010, 09:13 PM
ShakinJoe's Avatar
I have the same expression on my face when reading this post that I did when I first saw John Holmes in a "movie"!! The "aw come on" look.........................
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 01-13-2010, 06:21 AM
