-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Cheap long hood...Another back date project (http://forums.pelicanparts.com/showthread.php?t=716480)
cnielsen 08-02-2015 09:58 AM
http://forums.pelicanparts.com/uploa...1438534524.jpg
http://forums.pelicanparts.com/uploa...1438534611.jpg
http://forums.pelicanparts.com/uploa...1438534641.jpg
http://forums.pelicanparts.com/uploa...1438534668.jpg
http://forums.pelicanparts.com/uploa...1438534691.jpg
http://forums.pelicanparts.com/uploa...1438534711.jpg
Dpmulvan 08-02-2015 10:53 AM
Great job,beautiful car
vintagecarlover 08-02-2015 01:26 PM
Great vision. looks delicious.
cnielsen 08-02-2015 09:23 PM
Project of the day was backdating the door panels. Luckily most of the attachment points are still there but I had to drill a couple holes but the biggest headache was scrounging the garage for all the parts to make it work.
Also got the dash trim installed.
http://forums.pelicanparts.com/uploa...1438575672.jpg
http://forums.pelicanparts.com/uploa...1438575710.jpg
http://forums.pelicanparts.com/uploa...1438575734.jpg
cnielsen 08-02-2015 09:24 PM
Still need to install the check straps... I'll do that when I install the vapor barrier :(
quattrorunner 08-02-2015 09:41 PM
Wow love the colors! Looks so great.
Jonny042 08-04-2015 06:21 AM
Great work thanks for sharing!!!
cnielsen 08-08-2015 10:28 PM
Spent the last couple evenings sorting out all the cut wiring in the trunk. We also mounted the crossover oil lines and starting to mock up the fuel tank mounts as well as the fuel lines.
I'm dreading hooking up all the fresh air system but that's tomorriws project.
http://forums.pelicanparts.com/uploa...1439098073.jpg
al lkosmal 08-09-2015 08:09 AM
nice build Chris...........
regards,
al
cnielsen 09-12-2015 10:26 PM
Where do these funny looking parts go???
http://forums.pelicanparts.com/uploa...1442121830.jpg
Installed the pedal assemble and some hydraulic lines to replace the clutch cable ;)
http://forums.pelicanparts.com/uploa...1442121946.jpg
cnielsen 09-12-2015 10:35 PM
And now that the mechanicals of the interior are wrapping up, we can install the seats.
http://forums.pelicanparts.com/uploa...1442122517.jpg
http://forums.pelicanparts.com/uploa...1442122542.jpg
cnielsen 09-12-2015 10:41 PM
And taking some critical clearance measurements for the motor.
http://forums.pelicanparts.com/uploa...1442122886.jpg
Cag4 09-13-2015 09:04 AM
What seats are you using there? I assume you had them custom trimmed along with the door and dash panels? *Very* nice!
cnielsen 09-13-2015 10:55 AM
The door panels are simply reupholstered 69-73 factory door panels.
The dash parts are also factory 69-73 parts but I had to trim the AC side vents so the aluminum panels could sit flush with the rest of the dash. Also backdated the ventilation slider levers. The glove box was 72-73 I believe, and we had to modify the body a little so the latch mechanism would still work.
The seats are are Recaro Pole Positions that we cut the integral head rest off and grafted in the eustation tubes and headrests from a 69 seat. Sounds easy but this was fairly difficult and very time consuming to get everything correct.
onboost 09-14-2015 01:23 PM
But now you have the ultimate early sport seats! :D
Nice work as usual!
motofoto 09-14-2015 01:32 PM
Wonderful work on those seats! Had no idea that was even a possibility. Very much worth whatever effort was required for that final result. Love to see any behind the scenes type stuff for that project.
Antonov 09-14-2015 07:41 PM
Seats turned out amazing. More photos please.
Scottc714 09-14-2015 09:26 PM
What a nice car and thread! Unbelievable amount of work
al lkosmal 09-15-2015 05:00 AM
Chris,
I like the interior Chris. Simple and well done, with the nice touches that you seem to excel at. Well thought out.
regards,
al
PS: Is this one ready for Treffen?
cnielsen 09-15-2015 06:45 AM
Thanks, I'll try to find some pics of the seat fabrication. My upholstery guy (McFarland Upholstery) said they were VERY labor intensive! Of course you need to find a pair of donor pole positions and donor head rests/tubes.
Al, sadly the car won't be ready for Treffen. We had some delays with the motor and transmission but it should be all done by mid November.
