How much HP from my engine? (3.4L)
What the title says... How much power can I expect to get from my engine when all is said and done?
My engine specs: 3.2 liter base that will become 3.4 (98 mm) during this spring. (Starting assembly of the crankcase now) CR 10,5:1. Tec3r EFI, sequential injection, twin spark, knock sensor... Rarlyl8 1 5/8" headers w/heat. Dansk sports muffler 2in1out. PMO 46 induction. DC43 cams. Heads are overhauled and basically stock. Is 280 HP a good guess?
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=16659 |
Member 911 Anonymous
about 20% increase
I am think very hard about doing this, started the price list
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Diss Member
More likely 260ish unless you have some internal work so you can spin it faster. You will need to get the air/fuel and the timing just right which is confusing with the 46 PMO induction and sequential injection. Are you using PMOs as just throttle bodies?
Remember the engine is only an air pump. The quantity of power extracted from a given quantity of air-fuel mixture is surprisingly fixed. If you want more power you have to pump more air: Make it bigger, make it spin faster, or compress the air before it goes in.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Diss Member
BTW: Seeing that you have twin plugged it...
Any reason you aren't going to 100mm P&Cs? You are already putting out money for the bigger cans so get the largest that will fit. 95mm = 3164cc 98mm = 3367cc 100mm = 3506cc
From what I read, it sounds like a great start. If I where to take an educated guess, I would say around 250-270 range. Put her together and keep us updated on the final numbers.
Senior Advisor
pmo itb's my guess
08 Cayenne Turbo |
my guess is that is a good guess with sequential injection.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I know, I am up against some experienced guys here, but I have seen mildly modded but well balanced 3.2s making numbers upwards of 250. I'd say your own 280 is my bet as well.
Good luck!
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
non-whiner
Exhaust is really important. The set up is on the cusp and the difference depending on exhaust can very +/- 30 hp, so what is your exhaust set up?
"Too much is just enough." |
HELLO OTTO AND ALL THIS IS INTERESTING TO ME AS I AM IN THE MIDDLE OF DOING ALMOST THE SAME SETUP.. IT IS MY FIRST BUILD AND I AM DOING IT WITH GREAT ADVICE FROM A GREAT ENGINE BUILDER TUNER EVEN THOUGH I AM DOING IT MYSELF
LOW MILES 88 NA 3.2 BORED TO 3.4 AND RECOATED.. DONE BY EBS CUSTOM FITTED PISTONS 10.6:1 HEADS TWIN PLUGGED AND COMPLETLY REDONE/FLOWED BY XTREME SLIGHTLY LARGER VALVES ARP STUDS LIGHTWEIGHT VALVE TRAIN TIT.RET. ETC RODS AND ROCKERS RECON'D LIGHTENED 594/595 WEBCAM TEC3R ITB IGNITION/INJECTION SEQ.CAM/CRANKFIRED 46 PMOS BB 15/8S RACE HEADERS W/HEAT BB 2 IN 2 OUT RACE MUFFLER, OR THE INDIVIDUAL STUBBY MUFFLERS MY BULDER SUGGESTED THAT WITH PROPER TUNING, I COULD GET 320-340 AT FW ON 95 PUMP GAS WITH THIS SETUP. SO I AM WONDERING WHERE YOU CALCULATIONS COME FROM AS THEY AFRE QUITE DIFFERENT THAN MINE ![]() ![]() ANYWAY ITS A GREAT PROJECT.. JUST HOPE I CAN GERT IT BACK TOGETHER AND KEEP IT IN ON PIECEC FOR AWHILE BEST FRANK RAUSCHER@WISTAR.ORG |
Danish 911S driver
I would expect 280-290. Not quite comparable but my 3.0 Liter engine makes 260 in this trim:
930/Carrera engine block 95 mm cylinders JE pistons 10.5 comp. Adjusted to 10.2 Carillo rods 3.0 Euro Carrera/2.4/2.7 crank Carrera 3.2 heads with new valves and guides. The heads were fitted with a special flange and drilled to accept the MFI injectors. GE 60 cams MFI setup with throttle boddies and stacks from a 2.2 S KN aircleaners Dansk Stainless steel heat exchangers Stainless steel 2 in 1 out muffler. I have now replaced the heat exchangers with a set of 40 mm headers. I am also going for a pair of 42 mm throttle bodies, as the ones from the 2.2 are way too small for the Carrera 3.2 heads. That should add a bit of HP... /Christian
Christian 1972 911 S - 3.0 MFI in the making of an ST: http://forums.pelicanparts.com/porsche-911-technical-forum/733424-another-st-build-time-denmark.html |
The short answer: Price. I had my Stock cylinders bored and replated. 98mm is the limit for boring those.
PMO ITB's 46mm, yes.
![]() Sequential injection is not needed, but I read that makes for a more steady idle.
Thanks guys
I think maybe my question is a bit like asking how long is a rope. I'm very exited to get the final results... I chose to stay below 7000rpm to avoid stressing the engine. This is primarily a street car after all, but will see some trackdays as well.
My 3.4 with 98mm mahle, dc20 cams, sport pre/main silencer, 10.45:1 CR, single plug and remapped has dyno'd between 269-274 at flywheel
I have now fitted headers so hoping to see a minor jump once remapped This is on 99ron UK fuel
Shirish 1987 Carrera, Granite Green |
DC43's can pull all the way to 7500 so you have the potential to be +300hp.
It will most likely be determined by your exhaust system choice and layout.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Just to add to Shirish's post, his is breathing through a normal 3.2 intake (with a larger throttle body), so you should do better with ITBs.
A better comparison is Andy Perks 3.0, with DC60 cams, 1 5/8 headers and Jenvey ITBs that made 285fwhp turning no more than 7000rpm. So you should be north of both those engines. There are a ton of custom mapped but fairly standard 3.2 engines making 250+fwhp (see the 911chips website for example), so anyone who says you will only get 250-260fwhp is IMHO highly pessimistic. |
Thougt I'd bring the result from this engine build. It has been on the road for a while now and I finnaly had time to get it checked on the dyno.
The result was 281Hp at the engine at 6300 rpm So my guess was pretty much spot on! ![]() I'm very satisfied with this result, and the fact that it is very streetable and trackable is a big bonus. It actually pulls hard at 3500. Max torque is 328 Newton at 5250rpm. Not too shabby ay?
non-whiner
Not too shabby, yes!
Nice job and thanks for following up.
