Sent you a PM.
Member 911 Anonymous
How many of you that swapped to LED SPOKE will be at Pelican's Cars and Coffee, would love to se them in person
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I am very happy with my LED brake lights. I did notice that the lights come on dim whenever the ignition is on. I don't have a third brake light. I assume there is some current flow via the cruise control brain. I don't have a cruise control actuator or cable, so I could just disconnect the CC brain. Anybody else see this. It really is of no consequence, just an oddity.
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Reiver
Must be something else. My car has been in southern Az or Cali for it's 32 years so the electrical connections are almost like new. No moisture or corrosion issues. I suspect the issues most have relate to that.
De Oppresso Liber Strength and Honor 5th Legion Last edited by Reiver; 10-14-2015 at 07:02 PM.. |
Thanks, Reiver. Your 83 may be different. 83-84 were transitional years in many ways.
I hate people who answer their own question, but here goes. Since I don't have any mechanical parts to my cruise control, and never use them on these kinds of cars anyway, I just disconnected the CC brain. Lights function normally now. Dave
Now I have a question for Spoke:
Jerry, you mentioned that the EP36 LED flasher is plug and play on (some of) these cars. On my 84 the flasher appears to be 4-prong with a connection for tachometer. The EP36 is three prong. Maybe it just doesn't matter. Will it work with my car if and when I switch to LED turn signals? Thanks, Dave
About the brake LEDs being on gently, the CC control unit must have an input impedance which drains some current into the unlit brake bulbs when the brakes are not active. Standard bulbs have a real low resistance (like 10 ohm) so the little bit of current from the CC through the bulb creates very little voltage. With these LED boards, the resistance of the boards below about 7V is infinite. Thus the CC control signal tries to drive a small current into the "unlit" LED. The LED voltage goes up until the LEDs become forward biased around 7V. The LEDs then light a little. The LEDs don't take too much current to light up. I'm hoping the current from the CC signal is less than 50ma. If so, I'll find a place to mount an extra resistor on the Brake and 3rd brake boards. I could use some help to determine the amount of current. If you have a voltmeter, I'd like to send you a couple of test resistors so you could measure the voltage drop and calculate the current. Let me know if you can do this. |
Sent you a PM.
EP36 Flasher
I bought the V.1 rear turn signals/running lights. They are great and offer so much more rear light.
I am using an EP36 flasher (purchased from Amazon). Works perfectly for the application but does blink a little faster than stock. My car is an '88 and the original german relay was also 3 pin. Regards, Hiro Edit: To clarify - I bought the rear turn signal boards that were on SPOKE's car mentioned on page 3 and 4 of this thread. These were his first version and I think he was working on a second version with different side light set-up. These are very bright from all angles. I can't imagine driving without them now because they offer so much more running light. Sorry I don't have a better picture.
Yeah. Looking over the diagrams for 84-89 The 4th connection is either not used or labeled as turn signals for trailer. On my 84 the diagram in my Bentley calls the blue/white wire tachometer, but there is no such wire on the tachometer diagram. I bet a 3-pin ep36 would work just fine.
Thanks, Dave
Hi Spoke,
PM sent. Dave
Hello Spoke,
PM sent Mike |
I sent you a PM last week regarding a package (front runninglight/turnsignal, rear brake light/running light, rear turn signal, third brake light). Haven't heard back from you. Are you offering packages?
Thanks |
I can offer some discount if buying multiple sets. I'm selling these PCBs at near wholesale pricing so don't have a lot of wiggle room. There are a couple of things going on right now with the LED brake lights. This has to do with interaction of the cruise control unit and the LEDs. I have to get a couple of test pigtails out to a few guys to determine how to correct this interaction. As such, I don't want to release any LED brake boards until we can figure out how much ballast resistance to add to the boards to satisfy the CC unit. |
Congrats on the wedding!
Looking forward to buying a LED package from you. |
Coram Deo
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Very interested in the front turn signal that lights steady bright white and flashes amber when turn indicators are flashing.
I have Euro Clear front turn signals and think this would look great especially in the LED white hue since I'm replacing my stock headlines w/ Fozzy/Francois's HID units. Are these currently for sale? |
I've been putting ballast resistors on all the turnsignal boards that I design. I've found some LED-ready flasher relays that need at least some resistance in the load to start flashing. |
Dial 911
How bright
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 10-23-2015 at 09:03 PM.. |
