Voltage test results:
Test 1: 3.0 V LED's off.
Test 2: 2.5 V LED's off.
Test 3: 2.0 V LED's off.
test 4: 1.5 V LED's off.
Test 5: Slightly below 1.0V LED's off.
My voltmeter is analogue, pigtail was inserted into third brake light socket.
Old 11-02-2015, 12:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #281 (permalink)
spoke's Avatar
Excellent measurements Keith. Understood about the analogue voltmeter. You can only do generalizations of a value although your data is good.
There is one more test to finish this out and that is driving the car and checking if the CC still works. I would like to see this tested with the GND tap wire connected between resistors R2 and R3 such that 300 ohms are in series.
I'm fitting the brake boards including 3rd brake boards with 300 ohms each. With 2 brake PCBs the resultant resistance is 150 ohms. If the CC works with 300 ohm, there will be plenty of margin with 150 ohm.
Disclaimer: I'm asking you to drive your car w/o a 3rd brake light for this test. Feel free to decline to do the test as your safety will be somewhat compromised w/o a 3rd brake light.
Old 11-02-2015, 01:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #282 (permalink)
spoke's Avatar
Would like to determine the CC control wire input impedance.
With these measurements, the input current measured at the 3rd brake light is:
Ohms Volts Amps
100 1V .01
200 1.5V .0075
300 2V .0067
400 2.5 .00625
500 3V .006
If we assume the input impedance looking into the CC control wire is resistive to VBAT = 14V, we should be able to apply these voltages to the input and get the same current.
Assume the input resistance is 1750 ohms; current therefore is in parens():
Ohms Volts Amps
100 1V .01 (.0075)
200 1.5V .0075 (.0071)
300 2V .0067 (.0068)
400 2.5 .00625 (.0066)
500 3V .006 (.0063)
Not a bad correlation; not exact but close enough for this analysis.
Old 11-02-2015, 01:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #283 (permalink)
With GND wire connected between R2 and R3, CC works well!
Old 11-02-2015, 02:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #284 (permalink)
froggert's Avatar
Will this change have any effect on cars without cruise control?
Old 11-02-2015, 04:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #285 (permalink)
spoke's Avatar
This won't affect cars w/o cruise control.
Old 11-02-2015, 08:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #286 (permalink)
Reiver
Reiver's Avatar
I take it this is for 3.2's/ '84 and up cars?
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-02-2015, 08:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #287 (permalink)
spoke's Avatar
I'm told the brake housing is the same from model years 69-89. As long as the cruise control unit in whatever year is the same or similar to the unit tested, it should work fine.
Old 11-02-2015, 09:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #288 (permalink)
Reiver
Reiver's Avatar
I've an '83 w CC (works) and have checked and have no brake light issue that I can see (in the dark). The 84's and up do have a different electrical system with the motronic etc...if that makes a difference.
Any other SC's out there having this light issue?
De Oppresso Liber
Old 11-03-2015, 07:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #289 (permalink)
carreradpt's Avatar
Pm to you Spoke. DT
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 11-03-2015, 07:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #290 (permalink)
RocketWrench's Avatar
Send a message via Skype™ to RocketWrench
Spoke, I realise you are in fire right now, but did you get my PM from last week? Could you ship to the UK, or to my Dad near Seattle?
Also, could you arrange the LEDs to the customer's order?
What is your view on in-car mood lighting?
Old 11-06-2015, 04:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #291 (permalink)
spoke's Avatar
I did get your PM. Sorry for overlooking it. I can ship to the UK or to your dad.
Here's a couple of quotes for shipping to the UK that I got for someone else:
USPS: $30, 10 days, no tracking;
USPS: $70, 10 days, w/tracking;
UPS: $95, 5 days, w/tracking.
I can arrange LEDs for certain patterns. That is how the round brake LED came to be.
I'm trying to get the front and rear turnsignals off the ground right now so I don't have time for custom patterns at the moment.
Old 11-06-2015, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #292 (permalink)
No problem - busy is good, it means its going well! Good luck...
Old 11-06-2015, 11:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #293 (permalink)
spoke's Avatar
Finally getting caught up with things after my daughter's wedding and the delay for the quest to find a solution compatible with the cruise control units. A pile of boards were shipped today. All boards paid for have been shipped with one exception going to Ireland while we work out shipping.
Here's a couple of pics of my car with the white LED running lights in the turnsignal bucket.
With the headlights on.
Old 11-07-2015, 08:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #294 (permalink)
spoke's Avatar
Making a frame to hold the 3rd brake light PCB in the inside window mounted fixture. After about 6 attempts, this frame seems to work well. Looks like something out of the new Star Wars movie.
The board and frame fit nicely.
The PCB is moved as close to the rear of the fixture as possible for the light to hit most of the lens.
The lens keeps the frame and PCB in place.
Old 11-07-2015, 08:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #295 (permalink)
Spoke, I'm loving your work, and I realise you might be finding suggestions tedious by now (?)....
BUT, I have two other ideas that Id like your opinion on:
1. LED brake lights in the roof vents above the rear window
2. Angel-eye LED around the inside of the headlight....
Thoughts?
Old 11-08-2015, 01:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #296 (permalink)
spoke's Avatar
Thanks, we're having fun making these.
I welcome suggestions and observations. That's why I keep posting in this thread. Lots of good ideas out there.
This would be a good place for an invisible 3rd brake light. There may be one on the market that would fit although the entire length of the vent is curved with the roof and most aftermarket LED strips are straight.
A board could be made to fit the curve then the challenge would be to find/design an enclosure.
Not sure I'm visualizing this. The headlight on my '86 930 is a sealed beam with chrome ring. Is this for another headlight style?
Old 11-08-2015, 05:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #297 (permalink)
Regarding the roof vents, I was thinking more of individual modules per vent, that it would be possible to have one vent showing, or all of them. I even considered having yellow lights on the two ends linked to the indicators....
The angle-eye effect is a loop of LEDs inside the glass of the main headlight like this:
Old 11-08-2015, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #298 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
You'd need to have the Euro H4s with the removable lenses to make that possible. Sugar scoops with the standard 7" sealed beams or even replacement H4s wouldn't work for that.
Kevin
Old 11-08-2015, 08:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #299 (permalink)
Ahhh, ok now I understand. I have the Euro H4s and have disassembled them a few times, so I imagine inserting a ring of LEDs to be reasonably simple.
But, I am no expert by any stretch and like a lot of things I think are simple, I'm often discovering different after considerable swearing..
Old 11-08-2015, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #300 (permalink)
