Eng-o-neer
For reverse lights: the brighter the better.
Jerry, I've just sent you an email - would love to get the reverse lights too if available. More in the email.
Mark.
84 911 Targa Carrera currently getting renewed |
Coram Deo
Spoke,
What I'd like is a white LED for the right side reverse light and a red one for the left to serve as a foglight. Can you make a mixed set like that? It would save me drilling holes in my bumper. The idea came from a thread here on the board....
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Where can I find the flasher relay in an 85 911? Anyone?
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
You should be able to use the EP36 available at most FLAPS. Just make sure it says "LED-compatible". Novita is the manufacturer. EP36 is an old part number and older EP36's are not LED compatible. Should be less than $15.
I just got the first PCBs and built one to try on my car. Here's what the board looks like.
Installed the reverse LED board in my car. The fit is excellent. I still need to design a position frame like the brake boards.
The LEDs are about 1.5x brighter than the bulb. At 3 foot, I measured the bulb output at 65LUX and the LED at 100LUX. ![]() The LEDs are on the driver side. The LEDs are cool white.
What I meant to ask was "where is the flasher located in the car?" Sorry.
I installed my front turn signals and the rear side lights and boy is that a difference. Nothing to add on the install; I cleaned the lights, the housing and the contacts pretty thoroughly and the parts fit perfectly. Now on to this flasher; where the hell are you.
Great product spoke
Spoke,
By chance has there been any inquiries for a LED board replacement for the rearward facing bumper mounted "fog" light? Sent via Jedi mind trick by the cat
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
The last couple of posts is the first I've heard of the rear fog light. I don't know much about it.
I can't see it being terribly difficult to install or build once all the reverse light tooling is set up. Using red LEDs instead of white will give you bright red illumination. Install the PCB with red LEDs and splice the reverse light wire on the driver side to your existing fog wiring.
The only thing is that light used for rear fog could only be used as such and not reverse. Only the other side could be reverse. It'd be a stealth fog light behind the driver side reverse light. I believe that countries that actually require rear fog lighting only require it on the driver side. I don't know any specific legal requirements for reverse lighting. I have only heard previously that requirements were only for a single reverse light as being needed.
LED Brake Lights
I can send you mine if you want to check it out. I can also post some pictures too, but if there hasn't been a demand then there is really no need. I know you've got your hands full with all the other boards.
Let me know Cheers Trevor
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 05-14-2016 at 06:39 AM.. |
Coram Deo
Please post some pics especially of the opened enclosure. I'm always looking for something new to build.
Finally ordered rear turnsignal boards.
These will be populated with either red or amber LEDs.
Porsche Nut
How is the quest for Early front turn signals going? 73 and earlier.
