Kind of Blue
Obligatory pic from my other thread:
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
https://en.wikipedia.org/wiki/Radio_Data_System
PTY (programme type)This coding of up to 31 pre-defined programme types (e.g., in Europe: PTY1 News, PTY6 Drama, PTY11 Rock music) allows users to find similar programming by genre. PTY31 seems to be reserved for emergency announcements in the event of natural disasters or other major calamities. TA, TP (traffic announcement, traffic programme)The receiver can often be set to pay special attention to this flag and, for example, stop the tape/pause the CD or retune to receive a traffic bulletin. The TP flag is used to allow the user to find only those stations that regularly broadcast traffic bulletins whereas the TA flag is used to signal an actual traffic bulletin in progress, with radio units perhaps performing other actions such as stopping a cassette tape (so the radio can be heard) or raising the volume during the traffic bulletin. AF (alternative frequencies)This allows a receiver to re-tune to a different frequency providing the same station when the first signal becomes too weak (e.g., when moving out of range). This is often used in car stereo systems. REG (regional)This is mainly used in countries where national broadcasters run "region-specific" programming such as regional opt-outs on some of their transmitters. This functionality allows the user to "lock-down" the set to their current region or let the radio tune into other region-specific programming as they move into the other region. CT (clock time)Can synchronize a clock in the receiver or the main clock in a car. Due to transmission vagaries, CT can only be accurate to within 100 ms of UTC. |
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
I looked it up too - it's actually this one:
Pioneer DEH-80PRS CD receiver at Crutchfield.com Seems to be available for $250-$300 at various vendors. Mark
1979 911SC Targa |
mark:
You sure -- the image for the DEH-80PRS doesn't look anything like the one that Rocketwrench posted and, if I zoom way in on the upper left corner of the faceplate on his image I can "JUST" make out DEX-P99RS |
Agree. The P99RS is quite good looking. I'd have been happy with that one in my car. The cheaper one, not so much.
FWIW, I am going to leave my vintage Charleston in the dash, but have it run into a Soundstream ST4.1000DB amp I will install under the passenger seat (4-channels @ 90W RMS). The cool think about the amp, though, is that is has Bluetooth for connection directly to mobile devices. This way, I can have an original look, plus updated sound (I already updated the speakers), along with verstility for mobile tunes. I just ordered, so will report back after i receive it and do the install.
Soundstream ST4.1000DB 4-channel marine/powersports amplifier with Bluetooth® — 90 watts RMS x 4 at Crutchfield.com |
To work properly when the car is turned off and on, it should be wired with Battery (constant power) to A7 and switched power (Ignition or accessory) to A4.
See bottom left column in the manual snippet below.
Gustaf Porsche 911SC -81 Euro Last edited by guli; 10-25-2016 at 01:16 PM.. Reason: Make it clearer |
Another option would be to substitute the bluetooth receiver for a cd changer . . . |
I tried mine again with Logic turned On and also tried with it Off. Only way the radio would power back on was if I turned ignition back on in 2 seconds or less. Maybe something with the wiring?
I need to get my priorities straight and stop trying to work while posting. Mark
1979 911SC Targa |
Checked out
A couple of questions re the Continental unit;
1. Can you stream music from iPhone (Pandora for example) via Bluetooth? 2. USB does NOT charge, correct? |
Checked out
Do you have battery and ignition correct? I had to switch them in my car. Pin 4 should be ignition and pin 7 should be battery +
Gustaf Porsche 911SC -81 Euro |
Checked out
If they were switched like that, wouldn't the radio stay on when the ignition was turned off?
