Cars and Cappuccino
This looks like a really great start on a possible new product. Couple suggestions:
Please post a video of the shifter in action. Many of us would like to see how it actually performs. I'd suggest you change the knob end to allow it to accept standard 901/915/G50-type shift knobs. A lot of us have different knobs we really like ( i.e. wood 917 knobs, crest knobs, leather knobs) and would be very hesitant to leave them behind. Keep up the good work and keep this thread updated.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
911 Abuser
![]() I will try to bring a gopro the next time I go for a drive. If there are any good dry days left this season. This isn't really a product. When I'm finished tweaking the prototype and move on to fabricate the final version I guess I could make a few extra but it will require buying a short shifter, the factory option version, and modifying it. And it won't be anytime soon, not before everything have been thoroughly tested. Right now I'm waiting for a thick sheet of carbon fiber to replace the aluminium flat bar. Results will be posted. |
Review Tyson's post #4.
The shift lever attempts to transfer accurate shift actuation in the gearbox. However, the distance between gearbox and shifter is an expanse of sheet metal that has less than ideal rigidity. This means a lever sliding into a fixed "slot" in the shift housing won't necessarily result in a direct 1:1 relationship with what you want to happen at the end of the 4 foot shift tube, especially if the vehicle is under torsional twist as when cornering/turning. Sherwood |
Sherwood, that is true, the rod length is a "problem" for the 915.
But, just a thaught..., given some "play" in the slots, this could provide the 915-neded "inacuracy". Further, the slots would give guidance and ths avoid clearly hitting a wrong gear. No?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
House the shift housing, shift tube and support bushings/bearing in an unrestrained rigid tube/structure which is in turn bolted onto the gearbox and the gates should be more applicable. Sherwood |
911 Abuser
Lets do some rough calculations. If the normal un-gated lever can be moved freely from 9 to 10 degrees (or 5mm of knob movement) towards the drivers side when in first gear. The total play is one degree and the gate slot should hold it at 9,5. With the movement ratio from lever to shift tube being something like 1:3 that gives the body and engine mounts +- 1,5 degrees of allowed twist. That is over 20mm of deflexion for each meter of width. I (or anyone) could easily set up an experiment to measure the twist in the car. Just remove the top plate and rubber. Select a gear. Pull the lever gently to one side with a rubber band to take out the play. Drive and observe the movement of the knob. |
Caveman Hammer Mechanic
Ultimate answer, no one sells them for a reason, they don't work as intended.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Maybe it's less technical they didn't offer a gate.
Maybe it's just because of the tower not allowing a nice design place for a gate. The center console is very low, the tower protruding, not as neat as those embedded gates in Ferrari/Maserati. If the gates leave lateral play, it should work. At least for all those many not throwing their cars in twists while changing gears. C'mon... Whatever, I love to try it!!
911 Abuser
My guess is that Porsche didn't want to make a fully gated shifter because it requires a precise adjustment of the coupler and frequent replacing of the bushings. |
#147 of 2096
Subscribed
Really interesting
#147 of 2096 |
Almost Banned Once
What someone should do is adapt a cable shift setup for our cars... Once adjusted I'd bet it would work perfectly regardless of what the chassis is doing. (Cable bracket on the gearbox) There are some very good reasons why most if not all modern manual cars have a cable shift.
This is a setup for a mid engined car.
- Peter |
Speed Metal Army General
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 10-18-2017 at 08:53 AM.. |
911 Abuser
http://forums.pelicanparts.com/porsche-911-technical-forum/363337-cheap-wire-shifter-discussion.html A cable shifter have several benefits but it doesn't come with a spring return. There would still have to be springs and a gate added inside the shifter to achieve what I want . And it requires cutting a big hole in the car to attach brackets to the transmission. In a mid-engine car like the 914 there might be more room but in a 911 all of the linkage and cables would have to fit inside the tunnel or be visible above the carpet. For those reasons I decided against cables. If I ever cut the torsion tube to add a G50 and coilovers I will look at cable shifters again. |
