Front and rear windshield seal recommendations?
Good morning - thanks for the chat about Orange County installers last week. Very helpful.
I wanted to ask a follow-on question about the seals as well. I'd imagine that the seals will vary by vendor. Is there any wisdom on the best front / rear seal to use? Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
Vintage Owner
I think the Porsche ones are preferred over the URO aftermarket ones, albeit at a much higher price. My car had the windshield replaced by the previous owner using an aftermarket seal and it’s OK, but not as nice as it could be. I’d love to hear other’s real world experience as well.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Pretty much every thread I’ve read on poor windshield fitment begins with using a non-Porsche seal. I insisted on Porsche seals be used as part of my glass out paint job and was frankly surprised that the shop was considering an aftermarket substitute to save a few bucks.
Thanks guys-I'll check under the couch cushions and buy the Porsche ones
Which car? If possible, switch to the 964 screens and seals. Better, and less headache.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Interesting - this is for my '74 911.
That said I am fighting my front windshield seal on my '75. I so not have a dash pad in it, and the a-pillars are naked. I cannot get a factory windshield gasket to seal. I was thinking the lack of vinyl (and the clips) is not helping my gasket seal. Can I drop a 964 gasket into a '75? Why is it better?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Few of tips from my windshield seal installation
1. POR15 around the frame if you have the chance..might as well 2. PLEASE buy an oem seal..I used the URO at first and my windshield literally fell off the car and cracked 3. I purchased my oem seal from Suncoast Porsche because I was paranoid after the whole incident Sent from my iPhone using Tapatalk |
Will use OEM for sure.
Can we get to closure on the 964 vs 911 gaskets please? Is there an advantage to the 964 ones?
trim. Another tip, you can use the 993 rear quarter window rubber seal to get rid of the aluminum trim piece on earlier cars and it looks beautiful. Good luck!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 05-10-2018 at 06:51 AM.. |
However, I do agree with not using a URO seal. Unfortunately I purchased two URO seals years ago, and will not be using them on my windshield since their master cylinder had just about killed me. Do yourself a favor and don't use URO seals. |
Follow-on question.
Are the Genuine Porsche and OEM the same seal? Or are they different and the one you really want the Genuine Porsche?
Use Genuine Porsche ONLY! They are different.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Got it, thanks for the clarification
Thanks for the info
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Pelican Parts Vendor
The redesigned seal has a new profile and the lip has been extended about 3mm to better cover the body gap at the corners. Dave at TRE Motorsports did the fit-ups for us, so it should be a nice piece. Pelican forum member 3Ddesigns911 has one of the new seals, and we look forward to him posting his review soon. |
Here's a post I did about the old URO seal vs. the OEM seal vs the Porsche seal.
http://forums.pelicanparts.com/porsche-911-technical-forum/895087-detailed-differences-between-aftermarket-porsche-windshield-seals.html Obviously the new URO seal might have a better fit. UROParts, did you also add more retaining ribs to the seal, add the second flap on the inside, and change the wide metal insert at the joint?
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
![]() Here's a snapshot of our new seal during redesign, prior to the final change of extending the lip (see red arrow) by 3mm. As you can see, the redesigned seal has:
Will ask the engineers about the metal insert. Hopefully 3Ddesigns911 has installed his new seal, and will chime in shortly. Last edited by UROParts; 05-11-2018 at 03:15 PM.. |
Still here
UROParts,
If anything, kudos for keeping it technical in this technical forum. I wish all vendors could do the same. Now if you can just fix the ... |
