Shift linkage question - should this bolt be tight???
In this thread from rennlist:
http://forums.rennlist.com/rennforums/showthread.php?threadid=48566&highlight=shift+linkage Should the bolt that is safety wired, that holds the shift linkage to the shaft from the transmission be tight??? I have quite a bit of play in my shifter (I have the Autothority short shifter as well) and I checked the linkage today and that bolt was a few turns loose! (no safety wire either!). Should it be tight, or not?? Thanks,
VT944 Brian 1985.5 944 Dodge Viper Blue on black/tan white face gauges throttle cam short shift kit |
As I recall I made sure it was snug and blue loctite on top of that..........and the airplane wire.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Safety wire. Used in many places aircraft just being one of them.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
