Shift linkage question - should this bolt be tight???
In this thread from rennlist:
http://forums.rennlist.com/rennforums/showthread.php?threadid=48566&highlight=shift+linkage
Should the bolt that is safety wired, that holds the shift linkage to the shaft from the transmission be tight???
I have quite a bit of play in my shifter (I have the Autothority short shifter as well) and I checked the linkage today and that bolt was a few turns loose! (no safety wire either!).
Should it be tight, or not??
Thanks,
VT944
Brian
1985.5 944
Dodge Viper Blue on black/tan
white face gauges
throttle cam
short shift kit
Old 07-27-2003, 08:59 PM
ae1969's Avatar
Send a message via ICQ to ae1969
As I recall I made sure it was snug and blue loctite on top of that..........and the airplane wire.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-27-2003, 09:23 PM
SoCal Driver's Avatar
Safety wire. Used in many places aircraft just being one of them.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-27-2003, 11:14 PM
