Engine build update
Hey guys its been a while since I posted, Just thought I would update everyone on the status of project redblaze. I got some free time the other day so I spent most of it taking measurments of my engine, Bores/piston to bore clearences/Pistons/ rod journals ect ect, Everything specs out perfect with almost 0 wear which is sweeeet. Now I gotta order rings, Anyone know if total seal makes rings for the 944 engine?? I also have a mound of new parts that I need to install, First I gotta clean everything and figure out if I wanna do any head work. Anways I will keep you guys posted and start taking some pics of the new stuff.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
I'm pretty sure I've seen Total Seals for '44s. I'll go through my bookmarks and see what I can find... It may take awhile, I have thousands of P bookmarks.
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
There are total seal rings, but only the 2nd compression ring. It's either the first or the second, but I'm about 80% sure it's the second one.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Hey pokey, Thanx for looking into that for me. I guess one total seal compresion ring is better then none. I have heard good things about the rings so I hope I get the same results. ANyone use them before??
As for Total Seal rings ( www.totalseal.com )
First ring - not listed second ring - T2166 - total seal - CR2166 - conventional They list them for street/track use. So I guess you would buy a normal set of rings, then swap out the second compression ring from the set?...
Zero 10 beat me to it.
Haha, I don't know if that is a bitter remark, or if I saved you time....
You actually saved me some time... Thanks!
