Defroster Button + Squeeling = ??
Hi everybody. Haven't been around these parts lately as the ol slushbox has been runnin solid. Hope everyone is well.
Gotta little problem I've been lax on following up on, hopefully I can get some pointers: A/C + Heat work like a charm, no problems there, but when I press the button for the front windshield defroster I get a cyclic (on and off) squeeling from up front somewhere. In addition to the squeeling sound the car runs a bit rougher until the squeeling stops. Only when i press the front windshield vent button (right below the recirculation button to the left of the fan knob). Any help, as always, is greatly appreciated. Thanks!
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Dog-faced pony soldier
Defrost engages the a/c compressor. If the belt is a little loose, it could be slipping on the compressor. Try checking the belt tension or you can run just the a/c to see if the symptoms can be produced that way.
Does it sound like it's coming from the engine bay or the fan motor area?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
I agree with Jeff...has to be the a/c compressor (because the engine runs rough) but what is strange is that you said the a/c works ok by itself. I'm not sure why the defroster would change the way the compressor works.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Perhaps the combination of the additional electrical load (from high fan speed) and the A/C compressor is enough to make the multi-rib belt slip?...
That or the A/C compressor clutch is going, but since it works normally on it's own I suspect not.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Good point Zero...didn't think about the extra electrical load. You may want to check the tension on your a/c alt belt.
Misunderstood User
Might be a low battery. Sometimes the alternator howls, initially, when the demand for amps spikes.
