Tie-rod options
I'm sorting out parts for a total steering overhaul.
Can someone give me a run down on which parts work with what. I have a 86 944 NA with power steering. I am going to buy this rack off ebay It comes with just the tie-rods, but says it fits all models. SO is it just the tie-rod ends that are different for pre 86 and post 86? I can find whole tie-rods for a 83-86 with power steering on PP. But cannot find just the outer ends for a 86 with power steering. So I can assume that all cars with manual steering are different then cars with power steering when it comes to tie-rods. Post 1986 have a different offset so do they use different tie rods and tie-rod ends? or just tie rods? Want to order this rack soon but if it shows up with tie-rods that wont work Ill be delayed and do not want to re-use my old ones. Just a little confused, and I haven't even factored in the TURBO part of this. Any help would be nice, Thanks.
-1986 944 NA |
Go with autozone. they're 190$ with a lifetime warranty.
dolor et pavor Copyright |
We dont have autozone in canada, do they have online ordering?
-1986 944 NA |
Autozone might not be a better deal. Out here in California (ironically, really close to the company that the OP referenced on Ebay), the Autozone unit is $200 + $143 core charge and, from the photos, does not include the inner tie rods. At PP those are $160 but include new outer tie rods too. So for a fully functioning steering assembly we are at $370 (don't forget $10 for new boots) going the Autozone route.
With the OPs rebuilder we get a rack for $295 (the price includes a $30 core charge) that includes the inner tie rods. These are, somewhat ironically, available at Autozone for $16/each or $32. So for new everything we end up at $327 and we don't have to do the whole charade on the bench with vice to install the inner tie rods.
-Stephen 00 Boxster S 6MT 03 Subaru WRX w/EJ207 swap 16 Cayman GT4 21 Genesis G70 3.3T |
Whos to say they would send the correct tie-rods? They say for all models (1978-1994) . Are the tie rods all the same with just different outer tie-rod ends? Im under the impression that there are different tie-rod lengths.
Would the inner tie-rods ends have to be adjusted on the rack? or is all adjustment done at the outer end?
-1986 944 NA |
Garage Helper
Up to '86 are a different length Tierod than the '87 and up. Also different lengths on the non Power steering '83 - 86, different on non power '87 and up. Joint ends are all the same on 924, 924S, 944, 928 and 968.
Autozone was a good deal for me as I drove to the store with my core and walked out with the correct unit, and with new ends $215.00 - still working good after 4 years. (Prices may be a little different since then though).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 08-04-2010 at 01:02 AM.. |
