veleno's Avatar
replaced clutch master/slave and can't get air out of line...help!
Car is a '90 S2
So I've replaced the clutch master, slave, blue hose, and hard like between master/slave. I used a Motive brake bleeder, raised the rear and bled the system with very little success.
I then raised the rear even higher, tried again, made sure the reservoir never got empty, and put between 5-10 lbs. of pressure on the reservoir and still no luck. Tried it with the pedal, got some pressure back to the pedal but still no luck.
The pedal continues to stay on the floor.
I can shift fine if I "eagle claw" the pedal up with my toes but damn that's not the way I want to drive around!
Any ideas what I can do to get the air out? I'm about to turn it in to the mechanic so he can give it a try...
Old 09-09-2013, 05:07 AM
Proprietoristicly Refined
John_AZ's Avatar
You may have an air pocket in the clutch hose you replaced (on your 88 944).
At the connector on the fire wall, pack cloths around the hose connector and with light pressure on the Motive brake bleeder, open the connection until fluid comes out.
OR, unbolt the slave from the bell housing, hose still attached --pull out slightly and try to bleed again with the Motive ---bolt up slave and test.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-09-2013, 06:15 AM
veleno's Avatar
Hi John,
Sorry, I forgot to mention that this is on my '90 S2 cab.
Which specific connector are you referring to at the fire wall? Are you talking about the blue hose that connects to the clutch master, or are you talking about the hard line that connects to the front of the clutch master? Are you saying I might have air in the clutch master?
As for unbolting the slave from the bell housing and bleeding it, what exactly does this do and how is it different from leaving it bolted and bleeding it (like I've been doing)?
Sorry for the questions, I'm still learning
Thanks for the help.
Old 09-09-2013, 06:50 AM
John_AZ's Avatar
Look at figure 21 on the Tech article to see the connector:
Pelican Technical Article: Porsche 944 Clutch Master and Slave Cylinder Replacement
Removing the clutch slave from the bell housing because there may be pressure on the slave piston to the clutch fork causing an air bubble.
Just ideas.
J_AZ
Old 09-09-2013, 07:01 AM
veleno's Avatar
Thanks John. I'll try the connector (it's in a different location on my S2) and see how that goes as that's the easiest to do.
Old 09-09-2013, 07:23 AM
Custom User Title
mikepellegrini's Avatar
If there's air left in the master cylinder, you'd wanna raise the front of the car.
Plus, watch that you're not sucking air in the intake line from the reservoir. It's awfully high up on the reservoir.
Old 09-09-2013, 07:53 AM
Capt Squid's Avatar
Another method is to attach a piece of vinyl tubing to the left front caliper bleed screw and to the clutch slave bleeder screw. Wrap a rag around both and start pumping the brake pedal. Works like a champ to push the air bubbles up to the reservoir.
Jim Richmond
944 Spec race car, SoCal NASA & POC
01 Boxster S
Old 09-09-2013, 08:47 PM
AFM #725
Gawernator's Avatar
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 09-10-2013, 02:03 AM
veleno's Avatar
Sounds like a good plan, but I'd have to bleed the brakes first as I used better fluid and want to get the old one out first.
Old 09-10-2013, 03:37 AM
flash968's Avatar
since you replaced the parts with all new parts (not rebuilt or DIY rebuilt) i would tend to say that these are not the issues.
since they share the same reservoir, and any contaminates there would make their way to the reservoir, bleed and flush the brakes first.
try 10lbs of pressure, with fluid in the motive as instructed. work from the right rear wheel first, then to the left rear, then the front right, then the left right.
then move on to the slave.
Old 09-10-2013, 07:21 AM
Frankly my dear....
rhett's Avatar
Thumbs up
That's why I like this forum - I would not have thought of that technique! The only thing I would do is ensure the caliper I was using had been bleed (to get the crud out) as I would not want to push that into the clutch hydraulics. Otherwise...
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 09-10-2013, 09:06 AM
I had the same problem & I rigged up the pressure port of my Mighty Vac to a cup of brake fluid to "push" brake fluid from the slave up to the reservoir. It was a time consuming pain but it did get the last little bubble out. The thinking is that the air bubble wants to go up and out, not down and out.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 09-10-2013, 07:38 PM
The passageway from the main master reservoir to the clutch section of the reservoir is very small. Fast bleeding can lower it's level allowing air to enter the clutch master. Try raising passenger side to force better flow. But really, pressure bleeding from the slave sounds like the best idea....wish I had thought of that!
Old 09-26-2013, 09:34 AM
