JH924S's Avatar
Send a message via AIM to JH924S
engine sensors?
how do these actually come out. i have taken every bolt off and the bellhousing still wont come off and i have not removed the sensors as i cant see how they do . todwic i think u figured this out the hard way right? do they pull straight out? TIA
1987 924S black on black , does it get any better?
Old 11-30-2002, 10:15 AM
Scott R's Avatar
They get stuck over time. Be carefull but try twisting them a bit to loosen them up.
Once both of the bolts are removed that just slide straight up. But the last two times I have done one they were a bit frozen.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-30-2002, 10:50 AM
JH924S's Avatar
thanks a lot, man are they a pain to come out in this cold weather and no room to work with
Old 11-30-2002, 11:19 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Hell, just take the bell housing off, and the important half comes with em!
TDC and RPM sensors from a Junkyard: $60
The bracket to hold them: $5 xtra
Knowing to pull the sobs before you yank off the bell housing: Priceless
They fit in real tight, try some WD-40 and let it soak for about 20min. Soak em real good.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 11-30-2002, 04:13 PM
