MPDano's Avatar
Originally Posted by vdubr928 View Post
Black somke is usually fuel (rich) problem. Blue is usually oil. Set your timing after you double check all your vacuume lines. Then drive the car a few miles. Your computer is still learning your mixture settings. If that doesn't fix let us know.
Whew, this is good to know. Blue is what you don't want to see.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-06-2009, 08:58 PM
vdubr928's Avatar
I don't like running that much advance. Tend to stick to stock settings on a stock car. Less problems. detonation is a really bad problem and you never know when your local fuel station (or the only one for 50 miles) will be out of higher octane gas. Not saying he's wrong just that I don't like taking the risk.
I think 10 ppl are posting on this thread right now
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 08-06-2009, 09:00 PM
ok, heres what i did, step by step...
1. removed fuel rails
2.lossened distributor enough to slide
3. removed spider-pipes removed intake manifold
4. replaced vacuum lines one at a time
5. replaced diagphram damper
6. removed throttle body and cleaned
7. reinstalled throttle body
8 reinstalled intake manifold freshly powdercoated
9 reinstalled spider-pipes freshly powdercoated with brand new gaskets
it didnt run and so i posted in this thread
i switched the 2 hoses that attach to the back of the throttle body and it started and ran with high idle rpm and black smoke but i figured it was ok cuz it wasnt warm yet.
installed the airbox and connected MAF- resulted in not starting
rechecked the vacuum lines but all seemed good
the smoke seemed like a timing thing to me. and when it was idleing, i had the timing light hooked up and working off the #1 wire, but i couldnt see the marks, they were on the underside of the wheel at idle. i figured it would spin around when at 3000 rpm but never got a chance to try.
if it jumped a tooth, it would explain the smoke, and the timing marks not lining up right? maybe ill move the tooth back and see if it works, if not, move it 2 the other way, if not, put it back and try something else?
ill also try to unconnect the MAF see if it runs again, if it does, this means my timing is off and its barly getting enough air when unrestricted my the MAF and under better timing it would run better and hopefullly with no smoke? it seems like everything right now is pointing toward a time issue?
are there timing marks on the teeth inside the distributor? or will i have to do the TDC of #1 and point the rotor toward #1 then rotate distributor? either way shouldnt take me very long, it doesnt seem too hard.
sorry for the long post but thanks so much for the help
1983 928 s automatic
Old 08-06-2009, 09:22 PM
MPDano's Avatar
Yup, do this one with the "ALL" marks lining up. Cams, Harmonic Balancer and Distributor. Borrow a camera and take pics of all marks lining up.
Old 08-06-2009, 10:21 PM
Network Native
Danglerb's Avatar
Replacing vacuum lines one at a time is great, if the previous owner had them hooked up right. Get a vacuum diagram and double check all of them.
Old 08-06-2009, 11:44 PM
why do i have to make sure "ALL" the timing marks line p if just the ignition is off? shouldnt i just have to line up the spark correctly to the cylinders? or is it just precautionary? can someone show me some pics of the timing marks so i know what im loking for when i do this?
do i need to remove all spark plugs to turn the engine? and its a 27MM socket correct? and all i do is turn it till all the marks line up, then turn the rotor until it points to the #1 spark plug wire, then it should be close enough to use a timing light? last time i messed with timing on anything i really screwed things up : / i dont want that to happen to this car so i just want to be 100% sure of what im doing
Old 08-07-2009, 06:09 AM
928worldwide's Avatar
Posting for help is great isn't it! Luckily my cars are reliable for the most part or I'd be at it all the time too.
Good luck Bro.
YOU NEED IT? WE HAVE IT! -USED 928 PARTS- http://www.928worldwide.com
Old 08-07-2009, 06:19 AM
my car was reliable too until i messed it up. anyway, back to the help...
thats what i need to to do time it right?
Old 08-07-2009, 07:10 AM
Heavy Metal Relocator
rhjames's Avatar
yep---time it right, just as I described in my earlier post.
make sure the vacuum hoses are correctly routed as well.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 08-07-2009, 07:24 AM
Fabio421's Avatar
  • Which diaphram did you replace?
Not really relevant here but your car has an AFM not a MAF
Are you sure you had it hooked up to the #1 wire? #1 is the front passenger side wire
Yes, you can turn the engine to TDC and then align the distributor to #1. This will either put you at #1 TDC or 180 degree out
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 08-07-2009, 07:40 AM
rhjames's Avatar
could have been he didn't hook timing light to #1---good point Fab.....
#1 cylinder would be PASSENGER side, front of car.
--Russ
Old 08-07-2009, 07:55 AM
MPDano's Avatar
I just want you to show us that you have it "ALL" timed right. Your not going to make any changes just yet. This is why I said take pics of it, so we can move on or explain how to get the time all lined up. Remember, we are only trying to help, you can always do what you want and possibly f&^% it up worse. I will look for a pic of where I found mine was off.
Old 08-07-2009, 07:56 AM
vdubr928's Avatar
Where are you located?
Old 08-07-2009, 08:51 AM
ok, thats fine, i really appreciate the help. ill take pics of the marks, im sure when i remove the plastic cam covers ill be able to see the marks. the diaphram i replaced is the diaphram damper that is between the fuel rails in front of the engine. its part of the fuel line. i replaced it because it had a clamp on the vacuum line attaching to it, now it doesnt.
[IMG]Photobucket[/IMG]
theres only one vacuum line to the distributer.
the thing with the clamp is the diaphram damper i replaced.
i will get pics of the cam marks lined up to show you, and to make sure i adjust the distributer correctly.
trafalgar, indiana
a tiny town somewhere inside the yellow circle
Old 08-07-2009, 08:58 AM
MPDano's Avatar
Remove just your cam gear covers for the marks. This is also a good opportunity to get a good visual on your TB condition.
Old 08-07-2009, 10:29 AM
MPDano's Avatar
Here you go brotha! The Arrows in "Green" are good to go. DO NOT use the marks pointed in Red Arrows as this is what made mine 180 degrees off.
Old 08-07-2009, 10:42 AM
vdubr928's Avatar
Well damn. Can't exactly walk down the street and help you out. I would if I could. Off topic can anyone explain why do many ppl call that the dampner and many others call it the fuel pressure regulator. This part from 928 Specialist. In my opinion a trusted source.
http://cgi.ebay.com/ebaymotors/Porsche-928-Billet-Adjustable-Fuel-Pressure-Regulator_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em 14QQhashZitem3ef732af3cQQitemZ270435266364QQptZRac eQ5fCarQ5fParts
Old 08-07-2009, 11:19 AM
MPDano's Avatar
Yup, that's the same as mine.
Old 08-07-2009, 11:21 AM
because people dont know? the fuel pressure regulaters are located just underneath each end of the airbox. but they look EXACTLY the same as the damper. they have different purposes, different part numbers, different names, and work differently. i know this because i was told it was a regulator and bought 2 different regulators to replace it but they didnt work (cuz they arent the same) finally i figured it out. the only difference in looks is where the fuel line connects to it on the opposite side of the vacuum line, its all threads not the little needle looking thing that the rubber fuel line attaches to.
Old 08-07-2009, 11:46 AM
