Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Engine swap pro
myskyon's Avatar
Angry big problem.......
ok now take a look at these pictures and please tell me what could cause this....
http://www.myskyon.com/gallery/v/porshe/bigproblem/
ok now the story of how this all took place...
i took my car to a shop to have them replace my oil pan gastket, rod barings, clutch, and brakes. they pulled the engine to do the work. then when i got the car back, i started to drive away and when i got into boost (14psi) the intercooler pipes blew off. they were never tighened down. and they had re hooked up the vacume line to the KLR witch was disabled due to me haveing an after market boost controller with gauge. then we got the intercooler pipes back on tightend down i drove away thinking every thing was good. not 50miles later (the next day) i was leaving work and i stoped at the exit of the parking lot and my car died. i tried to restart the car with the clutch pedal in it sounded like it was seazed. since they did the clutch. let out the clutch pedal and the car started with a loud knocking and a bunch of white smoke out the taile pipe. not good. so i called a tow truck and had the car brought back to them. they pulled the enginge again and the head just to find this. now i have never heard of this before and i know the ammount of boos i am pushing should not cause this. is there something they could have done to cause this? messing up the rod barings? anything? what would even cause this? i have heard of the problem with bleeding the cooling system causeing head gaskets to blow but would that cause this instead of blowing the head gastket? my head gastket is not blown. i dont really have the money right now though i can get it to fix this. but should i have to pay for it or should they?
Old 04-03-2006, 06:30 PM
Ornery Bastard
Were you drunk when you posted that?
It seems like a bad coincidence, honestly. I can't think of anything that would be directly connected to what they did that would cause your issue.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-03-2006, 08:15 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
I may not know exactly what I'm talking about, but it really looks to me like something was in that cylinder bouncing around.
Is the turbo missing any blades or anything? The marks on the piston and the head... I personally don't see any way for that to happen without some kind of object in there.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 04-03-2006, 09:13 PM
ilikemy944's Avatar
This circled spot - it looks like the piston was squashed... how the hell do you do that?
Brad Tompkins
Old 04-03-2006, 09:16 PM
Engine swap pro
myskyon's Avatar
yeah it does looked squashed but all i can think of is that there was somthing in there. and i just found some info that the head gastket could have went then it caused a hydro lock condition wich caused the cracked cylnder wall.
Old 04-04-2006, 05:18 AM
Ouch! Have you looked at the bottom end yet? It does look like something got loose in there. However, the markings are more pronounced on both "high" spots on the piston, with corresponding marks on the head. Something loose would not have discriminated and would have more than likely made similar marks randomly across the piston and head.
I would think a valve would hit the piston before the piston would hit the head, but is there any chance a rod bearing would disintegrate and create this type of interference?
Old 04-04-2006, 11:07 AM
ilikemy944's Avatar
I see what you are saying, it does look like the piston may have hit the head. I don't know what the clearance is in there, but if you think a rod bearing could have done that, if the piston hit the head, it would have caused the head to lift, making it look like a busted head gasket...
Dunno... Let's see the bottom end?
I'm guessing it is at that shop still?
Brad Tompkins
Old 04-04-2006, 04:45 PM
ilikemy944's Avatar
Someone on RL had an idea ;P
Lose end cap or broken rod bolt?
Shops fault?
Brad Tompkins
Old 04-04-2006, 06:53 PM
Send a message via AIM to Gold951
There was something in the cylinder to cause that damage. The reason the damage is concentrated on the high spots is, because that is where the piston compressed whatever it was between it and the head, the rest of the combustion chamber was not close enough to crush it between them. When the engine was torn down something was dropped or left in the intake ports or intake system somewhere, either that or something came loose inside the intake system, possibly when the intercooler pipes came off something got into the intake system somewhere and caused that damage.
I for one would make them pay for all the damage even if something got in there when the pipes blew off, it's their fault they came off. Be sure to check the turbo for damage as it is possible, but not likely that whatever it was went through the turbo first. Also don't take no for an answer I don't know what shop and how honest they are but, they will probably tell you all kinds of stuff to get you off their back.
Old 04-04-2006, 10:29 PM
ilikemy944's Avatar
Here, read this
http://forums.rennlist.com/rennforums/showthread.php?p=2942862
Brad Tompkins
Old 04-04-2006, 10:52 PM
Engine swap pro
myskyon's Avatar
well the shop has desided to pay for a new engine they still dont know what happened. i asked about the bottom end and they said it was all fine. so i am guessing that they just dont want to admit they messed up and are going to pay for it. oh and the head was not removed the last time it went into the shop.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 04-05-2006, 05:26 AM
ilikemy944's Avatar
Glad that they are gonna take care of you
Those are some really ugly pics
Brad Tompkins
Old 04-05-2006, 07:54 PM
ae1969's Avatar
Send a message via ICQ to ae1969
WOW...... something got inhaled by that engine..............
Definitely check that turbo.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-06-2006, 07:53 PM
Super Moderator
nize's Avatar
damn that is painful to see. if the foreign object (nut?) hasn't been located yet, you should definitely make sure it's found before everything is re-assembled.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-12-2006, 02:13 PM
