gearhead
Not really a Ruf, but will BaT buyer’s care?
https://bringatrailer.com/listing/1987-porsche-911-carrera-targa-14/?fbclid=IwAR22G_eRIoAC3GLLqTMc-PTy7NLcqPcXJlrcrlxJB7YioDsh8qgsf8AAcis
Looks like a nice car. You think it will bring better than 930 money or not?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I’d expect it to sell for a premium with the RUF bits on it, even though it’s not a full RUF conversion.
Registered Minimalist
shocked they didn't fix the trans before this auction. That's going to seriously nerf the outcome.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Perhaps I’m in the minority but, that car doesn’t do much for me. It does look like the mileage is accurate judging by the work orders and the overall condition but, why did the third gear synchro go out with such low miles ? These boxes are pretty robust but it’s usually second gear that goes first. Looks like it has a boost controller aka dial of death. I’m guessing it gets to low nineties. Maybe more given the low miles and the gawd awfully heavy RUF wheels and outdated, underperforming, overpriced RUF intercooler.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Will be interesting for me to see how high this goes.
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
There are a bunch of 930's that had various Ruf bits and pieces installed by authorized dealers back in the day (mine included); some of those mods add more value than others (as Mr. Bush pointed out). Does the average punter know the difference?
From my experience with the 930s I had / have, 2nd gear synchro' s 1-2nd shift around 55MPH are usually street driven. 2nd to 3rd gets used more often on track or open road as few if any 1-2nd shifts vs many 2nd to 3rd. Syncros, dog teeth are common on most 930 by 60K unless granny driven. Usually $2K,for syncro,s & $3K with dog teeth, so realistically should not be a big factor for just that.
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 03-18-2019 at 04:00 PM.. |
95.5k reserve not met. I'm surprised it didn't sell at that price
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
gearhead
I guess the seller thinks it’s special. I’m surprised to see it going over $90k to be honest. I was figuring $80-85k
Dumbfounded that BaT even allowed a reserve that high. Seller f..ed up, shuda sold it.
Former Options Trader !!!
The Dial of Death is a deal killer for me. You never know who cranked it up and trashed the motor even with the low miles.
$95k is ALL the money for that car IMO Seller's going to sit on it for a long time if he expects to get much more than that. Peanut gallery there ..... "Oh just drop in a G50"
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
Cost me $20k to learn that lesson and that was about 18 years ago. I am sure its more now.
I can’t count how many times I’ve been at a mechanic’s shop and seen an engine getting rebuilt because the dial was turned up too high. That dial should be set and never touched. If touched, it should only be used to turn it down when needed, not up. I think that’s what RUF’s original intention was with that dial, so he could turn it down in the winter time when the roads were bad.
gearhead
And the air is denser. Us high altitude dwellers welcome the free HP bump we get in the cold, but on an old car like a 930 it might be a problem more than a welcome improvement.
Yup, me too. 22 years ago. There's an old saying with those knobs- "they always run fastest right before they blow up"
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Mighty Meatlocker Turbo
Where some people get into trouble with those manual boost controllers is that they install and use them without having any sort of AFR monitoring device onboard. And of course, the 930's stoneage-tech ignition and fueling systems don't have knock sensing, active timing control, or active fuel enrichment (enrichment is based on boost pressure, but the stock WUR is very limited there, and even a modified one has its limits and does not compensate automatically when boost pressure is increased past what it was tuned for).
When boost pressure is increased, the dynamic compression ratio goes up (big bump in horsepower and torque) and that requires more fuel (enrichment) - if no increase in fuel (lean condition), then very high cylinder head temps result and detonation follows. So obviously, it is nuts (different than pNutz!) to install one of those controllers without also being able to monitor AFRs and without installing a modified/adjustable WUR which you've tuned for the added boost pressure. Last edited by Rawknees'Turbo; 03-21-2019 at 11:19 PM.. |
Eva
Not sure why a rather stock 930 with some RUF brand mods and wheels is now touted as a "RUF 930"....gimmick
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Still here
That would be the GR discount.
![]() The crappy pics do not help either with the BAT crowd. Last edited by pmax; 03-22-2019 at 12:25 PM.. |
