Pulling Engine?
I am doing other projects to my 1983 and want to keep it "rolling" while the engine is out.
Can the motor be pulled from above?
My thoughts are to loosen the engine supports from the subframe, raise the motor and then separate the supports from the block. The engine is locked up, so if necessary I can remove the intake and head for clearance.
Is this possible or practical?
Thanks,
Todd
Old 11-05-2006, 10:39 AM
SoCal Driver's Avatar
Have to drop the cross member down a bit to get the pan to clear. Then bolt the cross member back into place. My have to remove the sway bar and disconnect the backs of the a-arms to do this. Mark the location of the rear a-arm mounts with some spray paint.
Be careful with the hood. If you leave it on and open it too far it will crack the windshield.
Remove the sensor bracket and the radiator.
Automatics have additional concerns.
Old 11-05-2006, 01:51 PM
tnporsche's Avatar
I pulled mine from above, but I had to drop the front suspension frame to allow the engine to move forward some as it came up. Its not bad just 8 bolts counting sway bar. The hardest part for me was the steering wheel shaft. Be sure to put it back on as you go, and don't do like me and forget it and I had to drop the axle back down again to get it to hook up.
I am not sure if the same is required for all engine types
mine was the 8v non turbo
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 11-05-2006, 01:52 PM
Razorback1980's Avatar
I pulled mine from the top. I removed the intake, alternator and a/c unit from mine. I also did all the steps that SoCal outlined. I removed my hood, it's only four bolts and you need it out of the way. I have an auto, so I didn't have any clutch stuff on the back so I easily cleared the headlight bar but you should be able to do that as well. All in all...wasn't that bad. It's easy to tear apart..putting together is the trick!
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-06-2006, 08:18 AM
Where in this great State are you Todd?
Keith Belcher
'87 951 nautic/cancan
Old 11-06-2006, 09:20 AM
rudidelange's Avatar
I dropped mine from below, it is also the Porsche recommended method of removing the engine.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 11-07-2006, 07:01 AM
And every Porsche dealer has a full hydraulic lift to do an out the bottom engine removal. I don't like stacking four feet of crossed 4 x 4's under the car to remove the engine. Since it requires a cherry picker anyway remove it from the top.
Maybe when I win the lottery and build my dream garage with the hydraulic lifts I'll do it as Porsche does it.
Old 11-07-2006, 10:32 AM
armandodiaz's Avatar
I did mine from underneath, used 2 jacks on each side and dolly. I took off the head, for clearance, but I don't think I had to:
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
[email protected]
Old 11-09-2006, 06:59 AM
There is actually a whole thread here on which is better..top or bottom. It seemed like it was split evenly. I personally took mine out the top with zero issues. I did however remove the intake and alternator as someone suggested it would be easier. I am not sure if I had to or not. I just didn't want my car that high up in the air with me crawling around under it....that was the only reason I did the top.
Tom
Old 11-09-2006, 08:29 AM
