Help trying to fix lifter noise ....
96 328i 100,000 5/30 oil
Hello, I am trying to fix lifter noise. Please advise to the best method without tearing the motor apart.
I am about to change the oil. Should I run cleaner through the motor first. Seafoam?
What weight oil should I change to (thicker or thinner). Synthetic help?
Thanks for your advise.
Rob[B]
Old 04-26-2007, 06:20 PM
Jeron's Avatar
People will suggest thicker oil.
Unless it is exorbitant I'd just live with it.
IF you have reason to believe you have sludge or build up run some B-12 or Marvel Mystery Oil in the oil right before your next change.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-26-2007, 08:15 PM
Jeron's Avatar
I usually don't like thicker oil but a 96 might benefit from a 10w-40. I doubt it reduces the noise though.
Old 04-26-2007, 08:17 PM
