What about control arm replacement? Steering box rebuild? I track my car and these need to be done before the next outing. (no pressure )
Thanks,
Jim
Old 03-15-2003, 09:11 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Controla arm replacement is done, albeit no pictures. email me and I'll send it to you. It is a rough draft im sure I will change a few things. For instance, I am designing a tool that will allow you to install the rear control arm mounts without headaches. Putting those on had my anger factor peaked at 11. Let me tell you that human hands hitting forged steel at high velocity is not a good idea.
Old 03-17-2003, 08:25 AM
Jared....
You can tackle the rear wheel bearing changout if ya want......As you know I just did one...the wrong way..haha....so I learned the hard way also.
I will say however that it is a several step process for reassembly and one does need "the tool"...($250.00) unless you remove the entire swing arm ass'y & take it to a BMW dealer or shop..
Dave
Old 03-17-2003, 09:43 PM
Can I second the valve adjustment! For something that is supposed to be done yearly, a step by step would be great. Plus control arms and other rubber parts... what can be done by a shadetree, what can not... rear axles, maybe?
Old 03-20-2003, 12:35 PM
Senior Advisor
Javier at Pelican Parts's Avatar
Jared, i've got a Viking gs2003 commericail range with 8 burners 2 stoves, right know its got a max output of 35000 btus but this is capable of 62000 you got a tech article on how to re-build regulater valve with out blowing up my house? just thoght i'd ask.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 03-20-2003, 01:12 PM
For some reason the idea of gas and Javier together is not very appealing.
Old 03-20-2003, 01:16 PM
A viking...hmmm Javier must have a mansion In the hills to go with it.
Old 03-20-2003, 01:24 PM
Senior Advisor
Nope, look at my avatar, professional chef by trade and passion.
Old 03-20-2003, 01:26 PM
Ahhhhhhhh ok...what times brunch?
Old 03-20-2003, 06:03 PM
Senior Advisor
Well lets see, I ve got 8 fresh lobsters coming in tomorrow from Maine, for my bros b-day, lobster omlets for Sunday sounds pretty good.
Old 03-21-2003, 08:10 AM
I want an lobster omlette!
Old 03-21-2003, 08:11 AM
Getting back on topic here,
this is what i have planned in the immediate future
- Control arm replacement along with drop links and sway bar bushings.
- S.I. Board battery replacement and relocation
- On board Diagnostics
- Rear trailing arm replacement and bushing R+R
Plus a whole lot more, chances are i have a rough draft of whatever you may need. Email me at jared@pelicanparts.com if you want a copy.
Old 03-21-2003, 12:48 PM
sounds like good stuff! Say, Jared, didnt you do a valve adjustment article a while back?
thanks
jeff
Old 03-21-2003, 12:52 PM
Yeah,
do you need that one, Jeff?
At your convenience, im not in a big hurry, but want
to do it before I move in June.
thanks
Old 03-21-2003, 12:54 PM
It's already online here..
http://www.pelicanparts.com/bmw/techarticles/E30-Valve_Adjust/E30-Valve_Adjust.htm
Old 03-21-2003, 12:55 PM
blw blw is offline
I'd like to 4th (or whatever) the timing belt. I have to do one for an E30 and also for an E28 fairly soon...
Old 03-27-2003, 04:40 PM
