In the shop at Pelican
Jared at Pelican Parts's Avatar
What tech articles would you all like to see?
Im going to open this up and ask everyone what sorts of tech articles would you like to see posted for the E30?
Old 02-05-2003, 05:00 PM
Send a message via AIM to jamesthevaliant
what about some info about upgrading to higher flow fuel injectors. I would like to know what the most ideal setup is for aftermarket ones, and how to install them.
2004 325ci sport pkg 5 spd
1990 325is 5 spd
Old 02-05-2003, 07:03 PM
Bijan's Avatar
Send a message via Yahoo to Bijan
How about replacing the water pump and doing a timing belt.
Old 02-05-2003, 09:15 PM
These are already in the works.
Old 02-06-2003, 08:47 AM
Bijan's Avatar
When do you think the water pump and timing belt replacement be posted? I have bought the parts and was going to have it done at the mechanic.
Old 02-07-2003, 01:55 PM
Sned me your email address and i can email it to you. If you have the tools, and are somewhat mechanically adept, you could do it yourself and save some money.
Old 02-07-2003, 02:00 PM
how about info on how to replace the differential mounts and install a finned differential cover.
its no fun if you can't race it
Old 02-07-2003, 08:27 PM
Cool Articals
How about Front and rear wheel bearings. removal of back window deck & center brake light to clean brake light cover. (mine is very dirty).
Old 02-13-2003, 11:16 AM
Senior Advisor
Javier at Pelican Parts's Avatar
What type of car do yo have perhaps I could help.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 02-13-2003, 11:20 AM
89 325i
Old 02-13-2003, 12:19 PM
SMURFWARRIOR's Avatar
Send a message via AIM to SMURFWARRIOR
I really like to see a tech article on clutch replacement, adjustment. Looking at this sites list, it says it was to be included awhile back. What a great site!
We are what we do repeatedly. EXCELLENCE, then, is not an act but a habit. - Aristotle (something tells me he would have been a Porsche owner)
84 Porsche 944, Gold
91 BMW 318I, Alpine White
Old 03-10-2003, 01:34 PM
Smurf, send me your email address and i can email you more tech articles for what you need.
Old 03-10-2003, 01:38 PM
Lord Eros's Avatar
Right now I am waiting for the garage to call me back with a quote of price for the timing belt replacement. If it is too much $$$ I will be doing it myself.
*Lord Eros*
Old 03-11-2003, 05:41 AM
macandal's Avatar
Send a message via AIM to macandal Send a message via Yahoo to macandal
How about a step-by-step guide on how to rebuild an engine? (Or would that be a book?)
Old 03-12-2003, 09:20 PM
hoarker15's Avatar
I need to replace one of my front wheel bearings on my '84 325e, so I know I would like to see an article on that. Also what about a tech article on how to switch the rear diff. off a later e30 to a limited slip rear diff. off a 325is?
Old 03-12-2003, 11:44 PM
hoarker I already have something like that. Are you looking to do this?
Old 03-13-2003, 09:21 AM
hoarker15's Avatar
Yes, if you have some info on the replacement of the hub bearings I would love to have it. My Chilton manual does't do the best job of explaining the whole process. To do this am I going to need some specialty tools? My manual mentions some tool item numbers but I don't know how much these will cost? If I don't already have these tools, would it be cheaper to take it to a shop to do this? Or are these going to be tools that are used quiet often for drive train work?
As for info on swaping rear diffs would be also be real helpfull. I am not going to do this project for a little while, but is something that I want to do hopefully before next winter. Also do you know what year and models came with the limited slip rear differential that will fit on my '84 325e, and what the ratios are?
Thanks!
Old 03-13-2003, 08:07 PM
Lord Eros's Avatar
PROJECTS I HAVE PLANNED:
valve adjustment, S.I. Batteries (8675309), Repair a drivers-side window; the person who fixed the window motor previously did a shoddy job, ergo the window rattles and the upper limit is very noisy, and the switch is flaky. Bushings in the shifter assembly. Universals on the drive shaft.
*Lord Eros*
'87 325e (I've named her "Serina")
Old 03-13-2003, 08:09 PM
I plan on tackling the door stops pretty soon as well.
Old 03-14-2003, 10:06 AM
HOW ABOUT SOMETHING TO GIVE PORSCHE DRIVERS A BAD RASH! J/K
Old 03-15-2003, 01:33 AM
