installing c2 i/c on 930 q's
I have some questions on putting a c2 i/c on my 930. I am confused about the whole bov thing. Do I have to get the c2 style 90 elbow with bov? Can I use the stock elbow and put a bov in the aluminum tube after the 90? Unsure what is exactly needed to mount this..
1986 930 |
Macht Schnell
The BOV needs to be somewhere between the IC output and the Throttle body. The Vacuum/Boost control line for the BOV needs to come from just below the throttle plate. Here's where I put mine, it is in the front tank of the IC. http://www.lesgarten.com/pix/porsche/AAA_1147.JPG http://www.lesgarten.com/pix/porsche/AAA_1151.JPG That's a VERY large TIAL 50mm. It makes a hell of WHOOSH when it blows. Hope this helps. Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
resident samsquamch
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
resident samsquamch
Also keep in mind that you should NOT vent to atmosphere with a CIS based engine.
EFI is a different animal...
resident samsquamch
Not that you need to spend anymore money on this addiction, but I'd think about going with one of the more stout, billet type compressor by-pass valves (CBV, diverter valve, dump valve, BOV, hooter valve, whatever you wish to call it). The 965 factory original plastic Bosch valve will work fine, but after some miles, is prone to wear and failure. I'm running a stealthy looking Hyperboost valve that looks just like the factory part, only it's anodized black billet aluminum. Forge makes a nice one too.
http://www.stratmosphere.com/hyperboost.htm http://www.stratmosphere.com/forge_valves2.htm
sand_man, thanks for the info your other post made me drool enough to buy one of these guys. I just wasn't sure if I needed to use two divirter valve or one. It looks like one from the installs I have seen, but didn't the 964t use two stock?
les, that is sweet
1986 930 |
964t used only one Bosch plastiv BOV of recirculating type. It works OK.
Open air BOV cannot be used on EFI either as long as EFI is using AMM.
Thank you for your time, |
resident samsquamch
Let me know if you need any pictures and I'll snap them. And I agree, Les, that is SWEET!
Macht Schnell
Les
Yea I was hoping to vent to atmosphere...I like the sound. Why can't you with these?
1986 930 |
resident samsquamch
It causes the CIS flapper plate (in the metering housing) to behave erratically.
A fellow Pelacanite
AMM = Air Mass Meter.
With CIS that flapper plate is basically a AMM
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
ok makes sense now. thanks for replies
1986 930 |
Not quite, but it causes CIS to inject fuel that was previously metered up and then dumped overboard, causing an overrich condition.
resident samsquamch
And how does it do this? It's my understanding that it occurs via the flapper fluctuating. And FWIW, I've heard the inverse of what you just described...the flapper slamming shut and causing a lean condition. That's why I chose to say "erratic"...
resident samsquamch
BTW Goran, it's hard to tell from this whole internet thing, but I didn't mean my tone to have a defensive flair. I realize you know these fuel systems VERY well...in addition to turbo charging as a whole, and I respect your knowledge. And I do understand what you are describing. I'm merely pointing out what one of the more experienced shops in my neck of the woods explained when I was describing my plans to change intercoolers and run a different by-pass valve. Your explanation could very well be right one...
Cheers!
Macht Schnell
Les
does anyone know the part # for the elbow with bung for divirtor? I am trying to find it on ******** but not having any luck
1986 930 |
resident samsquamch
http://www.eagleday.com/rawagaexpi.html
thanks got it
1986 930 |
