If I Had a CNC Machine...
If you had access to a high dollar CNC machine what would you make. I'm interested in something guy's on here might want if it was inexpensive and custom. I have a friend who has a CNC business that is slow and thought maybe guy's wanted something on here.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al |
89 930.
Wheels,
Maybe RUF replicas? I want new ones but I'm out of money! I know this will stir up things but....... a aluminum cup holder ( one that looks and works well ), and when not in use folds away out of site. There is 2 things, and now a word from the Pro's.........(look at next post). |
Thanks Benny,
The wheels would be cool, but will be work. Cup holders would be easy but where would they mount from?
Manassas, VA
Got CNC?
No brainer...
Make some of these: ![]() I'll buy one. Ruf used to sell them. I would say the price point is between $500 and $1000. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Affordable center lock wheels and hubs?
Those exhaust stud drilling tools are nice too. |
7.0:1 > 11.3:1 > 7.0:1
Just an idea, but how about stuff with "930" or "RSR" on it: Fuchs center caps, custom hood badges, billet keychains, desk ornaments, shift knobs etc. Or how about clear anodized deck lid emblems milled from thick billet in script: "Carerra", "turbo" etc.
Metal Guru
Make intake blocks for EFI conversions.
One flavor for the stock manifold, another for the Carrera manifold. Make the Carrera ones taper to 32 mm.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I want one of these but can't bring myself to pay for it.
http://efinnegan.com/Porsche/Repair%20Maintenance%20and%20Miscellaneous%20info/seat-slide-mounted-cup-holder.htm |
resident samsquamch
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
This falls into the “ If I won the lottery area”
To build an efficient 4-valve air-cooled head for our engines. Of course this includes making the other required bits such as, cam towers, timing chain covers that adapt the heads to the block. There are several examples in Bruce Andersons 911 Performance Hand Book of early 4 valve motors. There is a nice photo of the 1978 type 935/71 Moby Dick engine. I suspect that some where collecting dust is a treasure chest of tooling , proto types, plugs, castings and a wealth of knowledge to bring this dream to life. Wouldn’t it be wonderful if Porsche would open the doors to these vaults and rekindle their bond with generations of Porsche Enthusiasts. Ok back to reality. How about designing and building a light weight rocker arm? Is your buddies CNC milling machine a 3 Axis unit?
Thank You for your time, Paul. We do because we can. 87 911 3.2 (Turbo conversion, build in progress, Thermal Barrier Coatings, High Pressure Dry film coatings) Modified heads, boat-tailed case, ARP hardware, OBX Header, 930 clutch disk, G50 Trans 89 5.0 Mustang convertible (For Sale) |
89 930.
Mabey something along this design, but folds into the ashtray, Now , get to work.
Forced Induction Junkie
How about a tasteful center console? Then you'll have your cupholders and ashtray. Machined aluminum and leather.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I would make hi-rev 2-stroke 3L straight six and install it into BMW E30 chassis.
Thank you for your time, |
Groan I have the engine you want but it is a V6 and called Mercury XS and has Direct Injection.
Center Console Redux |
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
4valve heads!
Yasin
Ole Skool - wouldn't have it any other way |
I do alot of R&D/prototype part development here for my customers. You guys name it and I can most likely render the CAD development in Solidworks. My most current CAD project are new throttle bodies for a few other chassis. I might be developing a new TB for the 997's as well soon. I need to land a 930 TB before I could consider interpolating the design over to your cars.
Short stroke, long rod motor. Use S50B30 dimensionality, reed valve case. 11.5:1+ static CR. Make a bedplate and pan design to isolate the cylinders from each other in the crankcase. Obviously make a new head sans valvetrain and Vanos. Ohh, could twin plug the bish(is only an 86mm bore though)...... Whoa!, just got a chill See now you're gonna make me waste more time and make something in Solidworks, hahah. Can you imagine what that thing would sound like!! I'm an oldskool Rotax tuner here from my snowmobile days, absolutely love that stuff.
Adam Hennessy |
I've been thinking about this a long time It would sound like V12. But how is oiling done on one of these? Is constant fuel flow required to keep cylinder walls lubed? In that case extra oil squirters underneath the pistons are probably needed in order to lube it when engine-braking.SAAB 92 two-stroker solved this with free-wheel assembly which is a bit cumbersome. It would also spoil the sound ![]() Thanx! /Goran
On the other hand, Merc V6 naval engine is compact, light and already works. But I dunno about oiling while engine-braking. EFI with continuous fueling to keep cylinders lubed would work but it would backfire as crazy when engine-braking. I would make extra fueling rail powered by external pump just ta keep lubrication at bay as maritime engines aren't subjected to G's or engine-braking. It would sound really really good and weight a lot less than V12 No flywheel to speak about = throttle response would be instant. It would sound like Carrera GT with two extra cylinders Add a small multiplate clutch (torque is probably low, don't need beefy clutch) and straight-cut dog box and it would rip! Tuned exhaust chambers could be sourced from snowmobile scene.But it has to be mounted into lightweight chassis or it would only sound good.
Thank you for your time, Last edited by beepbeep; 01-25-2009 at 07:49 AM.. |
