For others that follow, there are some good points some of us made in another thread "$100 fueler" that might fit in here like using the AIC-1 to drive a AEM Boost Controler and getting more fuel using the USA head's Lambda valve with a RPM switch to triger more fuel.
$100 fueler for 85-89 930's AEM Boost Control Valve: http://www.aempower.com/images/products/Installation%20Instructions%2030-2400.pdf
Infidel
Can we keep this thread alive please, i was enjoying it
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
Guys,
I talked to Steve and my CIS is done and the "mystery cone" is installed. I should have it back next week and will post pics of it . I'm still putting the Old Sled back together so it will be a while before the engine goes in. Unwired also anounced they were shipping the new units next week. I'll call Chris and see if mine is coming. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 04-28-2009 at 07:50 PM.. |
Sorry about going off topic here but I'm getting excited. The Old Sled is starting to look like a car again. Just finished sticking in the new Wevo, tube bushing, and PSJ joint coupling.
I'm fitting the new front bumper and lights. Glass and carpet next. ![]() ![]() Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 04-28-2009 at 07:52 PM.. |
Some of the VW guys have added a boost modified fuel presure regulator installed in the return to the gas tank to bump the system pressure.
Interesting! I like the idea of was to make the CIS safe with a manual boost knob. I like the MSD with boost retard so if boost is bumped, timming is pulled back accordinly. With this idea, the fueling might bump with added boost. |
RUF had what looks like an adjustable fuel pressure reg on the WUR of there 3.4.
I wonder if that was to buffer the WUR diaphragm so it would not get damage or some type of fueling strategy. Anyone know about the RUF system? |
Great thread. I've been enjoying reading and following.
Was the IA fuel head modifications for US heads or was it applicable to the Euro heads, most specifically the Euro 930 head? Also, is there a thread that details the IA modifications? I'm late to the party and have been searching threads but have yet to find an adequate description of the mods. Thanks Jim 1980 930 1995 993 |
A fellow Pelacanite
IA can mod either head. Each head will then flow more fuel. I asked Stephen which head will flow more fuel when modified and he told me the USA one will.
There are no details on the modifications but I was told by Stephen they are CNC'd to flow more fuel.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Thanks for the info. I assumed they were modified by removing material from one or more passages but I'll have to think a bit why a modified USA header would deliver more flow than a modded Euro. I've never seen the inside of either but assumed the Euro header already had larger passages (ie modified). Maybe someone with more experience can comment. Jim |
He was converting the Lambda heads to operate like a euro head.
The main reason these heads flow more it they are adjusted by the builder to do so. Thus, at every point along the arm travel they flow a given percentage of fuel, say 12%. Thus, if you set them correct at idle, they will be say 12% richer at cruse and 12% richer on full boost. To compensate correctly for this change the WUR should be reconfigured so the arm will move said 12% less with changes in air flow. This unfortunately this may limit the total amount of fuel delivered unless the control pressure it then lowered at higher rpm on boost like the Andial Fueler did. The work around it to clamp the boost enrichment function on the WUR until later in the rpm range and try to adjust around idle and cruse AFR's. Even without modifying the USA head there is more fuel to be had by 1) making sure you get full travel of the metering arm (reprofiled metering plate, Andial fueler, or lower CP/WUR) and or by taking over control of the Lambda valve with a different controller (Split Second w built in Oscillator). In theory, a modified Lambda head that has the Lambda circuit manipulated should flow more than the modified Euro Head. However, not one that I am aware of has tryed this yet.
I have one and I was told the 6 metering slits in the steel cylinder the control plunger is inside of are CNC enlarged. That lets more fuel through to the top side of the differential valves for any given throttle position a little above idle speed.
The lambda frequency or pulse valve is also removed and the banjo bolt that connected it to the lower side of the differential valve chambers gets a threaded plug. That fitting is just to the right of the large flare fitting fuel inlet line. The black cast iron euro, rest of world, and pre 1980 USA fuel heads do no have that threaded port. The other end of the pulse valve was banjo bolted in tandem with the return line from the warm up/control pressure regulator and when the pulse valve is removed that port gets a shorter banjo bolt so only the return line from the WUR is connected to that return line port. Lastly there are 3mm spring tension adjusters under the 6 - 4mm button head plugs on the top side of the fuel head next to the fuel injector line banjo bolts. These 3mm adjusters adjust the spring tension on the top side of the differential pressure valves. They act as small fuel pressure regulators, one for each fuel injector so you can fine tune the amount of fuel going to each injector. Turning the 3mm screw clockwise increases the spring tension on the top side of that valve and that lets a little more fuel flow through that differential valve and on to the fuel injector. The modified fuel heads have a dab of green or brown paint on each of the 6 - 4mm button head plugs showing that that 3mm differential valve flow adjustment under it has been changed or checked. It's impossible to figure out how the CIS fuel heads work without seeing cross sectional diagrams showing all the internal passageways, valves, metering slits, and flow restrictors with arrows showing fuel flow direction. |
Is there any spec that states what the stock (unmodified) flow rate should be out of the fuel distributer given s set system and control pressure? I haven't found it in the factory manuals but may be missing it. Also I don't have the little spec book which I need to obtain.
JFairman, thanks for your descriptions of thefuel distributor and the mods. Jim |
Jim,
I'm going to really confuse you here as I truly believe the 930 Euro fuel head will flow more than enough fuel to support 375- 425 Hp. Steve Weiner of Rennspor Systems says the issue is not a lack of fuel but the lack of air. The amount of air pushing on the metering plate determines the amount of fuel to the injectors. Steve had raced the old 934 and 935's when the 934 still used CIS. He has built high Hp 930's and worked on CIS for 28 years. He is also the first to tell you if your going to do a 930 build with 400 Hp + you want to go with EFI period. I have an 80 ROW 930 and am in the middle of a getting the old sled back together after a tear down and repaint. I have been looking at the CIS threads for years. I personally believe you need to know what you have and what you want before you start dumping big bucks on fuel head mods. All the normal 930 updates, cams, headers, turbo upgrade, ignition system, larger intercooler, boost springs, etc are logical bolt on improvements that give you predictable, proven, instant performance results. The fuel system is a whole separate issue and needs to be approached from a complete systems point of view. CIS is an antiquated mechanical system thats 36 years old and has a bi metal strip as its only electronic facsimile. Air goes in an arm goes down a piston goes up and fuel goes out but not quite as simple as it sounds. Check filters, accumulater, pump pressures, return ck valve, system pressure, control pressure, fuel lines, WUR operation, AAV operation, and spray flow and pattern. All these things need to be in correct working order before you take another step. Next and most importantly what are your afr's from idle to full rpm and boost. This can only be done 2 ways; a dyno run or installing an O2 sensor and some lm1 type logging device. Now if you are running lean and can not adjust the system to safe afr levels you might want to look at a fuel head mod. There are a lot of guys out there running fuel mods that are washing the cylinders and running pig rich constantly and can only jack with the control pressure to try and get it under control. I don't know how much it costs to weld up and recut the metering slots but a new fuel head is probably cheaper. I'm 66 have a junk pump and cancer, in 66 years I've made every mistake you can make and if you learn a little from each mistake the one that always comes back to bite you in the ass is I wish I had gathered all my facts before I did that. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 04-28-2009 at 08:00 PM.. |
Your post is not confusing at all... but from experience on more than one '87 930 with an innovate AFR gauge, I will say a stock USA fuel head will not give you enough fuel for over approximately 380 HP safely without doing some kind of adjustments to it.
The stock cast iron black painted euro head is supposed to flow enough fuel for 400-425 horsepower safely. By safe I mean around 12:1 AFR at 6000-7000rpm while making 375+ horsepower with no detonation at 1 bar using 964 cams, headers, and a bigger intercooler. Using SC or stock cams you probably won't be taking the revs quite that high because the power band runs out earlier than 964 cams. You mentioned welding up the cnc machine widened flowtech/imagine auto modified fuel head metering slits. The steel cylinder with the metering slits that the control plunger moves up and down in is removable from the bottom side of the fuel head. I'd like braze them up and recut them to the stock width in the middle area and then gradually taper them wider right at the top of the cylinder where the piston will be at full throttle when you need the extra gas. It seems like that would work well without a bunch of add on electrical and mechanical gadgets. It wouldn't be so overly rich in the midrange, but it would get the extra fuel flow from 5000 rpm on up where you need it on a modified higher output motor. |
I spoke to a 930 tuner years ago that modified WUR's to be boost sensing and to operate at a lower on boost control pressure for more fuel (Rice Fueler). He made me aware that even with lower on boost CP settings the metering arm still dose not reach fuel range of travel. He found that on a dyno at full tilt he could push the metering plate down further with a screw driver and flood the car. Thus, I am suspicious that modifying the metering pin is of significant value.
Another way to test this the additional fuel delivery of the stock head and that we are not accessing it is to set the idle CO very fat. Then run the car up and you should see that the top end gets more fuel even though you thought you were at a limit. What this is doing is changing the position of the metering pin relative to air flow and allowing it to advance further. Until doing this no longer adds any fuel up top, we still have fuel delivery capacity left. Thus, if we can get the metering plate to not stall, we can get more fuel. Steve Werner is the only tuner I have heard of that addresses this by relocating the hinge point of the metering arm. This allows the metering pin to travel further with any change in the metering plate position. If I recall correctly SW used to build a sweet 930 with gears, 3.5 twin plug w MSDs, 8/1 CR, ports, and .7 bar boost that was good for 425hp. Start to go much past that and the issue becomes premature ware and limited thermal reserve. It might be helpful if we knew if we are talking flywheel HP or rear wheel HP. I do not know if gross air flow is the problem at the HP levels we are talking about here. I think it is more how the metering plate responds to the air flow we have.
J,
I've kind of gone in a different direction concerning the fuel head. I have all the fuel system checks done injectors are out being cleaned and tested now. My fuel distributer is at Rnnsport Systems having a modification done to flow more air and assure full piston movement. Steve is also installing the velocity cone shown in the first part of this thread. I am installing a MSD 6AL Ignition, Boost Retard Module, and an Electronic Boost Controller. I will be running an on-board LM-1 and monitoring RPM, boost, vac and control pressure. I am of the opinion that the fuel mod and adjustable BL WUR are more mechanical band aids to try and control mechanically created issues that are mechanically uncontrollable. With these add ons I think it is impossible to create an optimal fuel curve consistently across the RPM band. This is, by no means an attempt to disparage anyone or any of these devices it is simply stating a factual account of hours of forum posts. I have yet to see the thread that states this is what I did to my CIS and I have a perfect fuel curve across the RPM band consistently. I also don't believe we will ever see such a claim. CIS was a marvel in it's time but it's time has passed, kinda like mine, and unless you spend 10 grand on EFI you will never get there. I do think that to get the CIS as close to optimal as possible you must be able to do closed loop control of the CIS control pressure across the RPM band. I think from what we have seen so far the digital WUR is very close to achieving that goal. If you think about it you can buy a DWUR for about $500.00 less than the cost of the fuel mod and a BL adjustable WUR. I also think Ignition timing control can add additional performance enhancement and detonation control but that's another story. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 04-18-2009 at 10:13 PM.. |
Forced Induction Junkie
That being said, I would still carry a backup mechanical DWUR in the front bonnet as a spare until I am certain the reliability issue will not be rearing its ugly head at the most inopportune time.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Apologies if you have heard this from me before.
I used the plumbing from the Andial Fueler and a Split Sec. Timing controller to make up what I called my electronic WUR. With this I did get near perfect AFR's at all points - curse or on boost. I was able to extend my gross fueling one more full point of AFR up top. Further, I was able to program in an ability to get the metering plate moving quickly with acceleration for less lag. From this I have to conclude that in theory the DWUR should be very effective and achieving its goals. It will also allow the increased flows of the IA head to be tamed. With my system, if there were to be a failure, you could just plug the WUR boost enrichment tube back in and be back to stock. Having said that, I am back to being interested in taking a mechanical approach to extending the limits of the factory systems. If you have ever seen the AFR curves for a stock 930 that is well tuned they are actually pretty good. That is because the three systems that determing the AFR's are all ballanced to each other. The stock fuel head, WUR, and more importantly the metering cone architecture is what determines the AFR curves. The motor was designed to make 300hp with some reserve built it. I think the fuel head can deliver about twice the stock fuel needs with adjustment. It has been done and 600fwhp has been had with CIS w/o additional injectors. Thus, I will boldly state that the fuel limit is near about 100hp per injector with approprate mods to the fuel head, WUR, and air metering systems. Doing this is a mater of making compensating modifications to not just the fuel head but to the rate the metering plate advances (cone design or plate design) and the settings of the WUR (cruse and boost CP settings). No one seems to take a full view of these three systems and how they work together. They tweak one and maybe two and never get all three ballanced to work correctly togeather. I firmly belive it can be done. Yes EFI is a better system and is the best way to acces power and drivability. However, at this point for me I would no sooner remove MFI from and 911RS as remove the CIS from a 930. That is just me. |
I fully understand everyone has an opinion on 930 CIS, what can be done and what can't be done to improve it. I love the old sled and much like my lovely wife I accept its flaws and idiosyncrasies and still love it. I can't afford EFI, I would not spend the money for EFI if I had it. But I do want to get the most out of the CIS I have. To do this I have tried to logically approach the entire system by first making sure all the components that support the system work the way they were intended to. With that being done we are always left with the one variable everyone ends up with the fuel distributor.
In almost every discussion it is assumed that CIS will not provide enough fuel to support the HP the engine is producing. That opinion, in many cases, turns to which fuel head flows the most fuel. It is much more like some male ego thing about who has the biggest dick than it does having anything to do with solving any CIS issues. I would bet that 90% of us out here have never dynoed to actually prove we don't have enough fuel; I know I haven't, but I also don't know if that is even an issue with my set up. I would bet 90% of us have enough fuel available and have never done the necessary testing to find out; I know I haven't. I have tried deligently to set a goal of having 11.9 - 12.1 afr's at 5600 RPM under 1 bar of boost with CIS regardless of what HP that ends up being. To put a system together that gives me the proven performance I can reasonably expect from the updates I have in a safe and reliable manner with no detonation. Untill I can read data that proves I cannot reach that goal with the set up have because of a lack of fuel I see no reason to do any fuel mods. After a lot of reading and several discussion with Steve Weiner, Bob Holcumb, Chris Fisher, and Chris Carrol I have come to the conclusion that I would modifiy the fuel head to get more air and facilitate full movement of the metering plate to allow full movement of the plunger and max fuel output. This has been done to make sure I am accessing all the available fuel from my fuel head without having to machining the metering slots. Once I have collected the data and definativly proven I have enough fuel I will be adding the DWUR to allow tuning of the fuel curve. I my opinion, presently, that's as good as it can be with CIS. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 04-28-2009 at 08:30 PM.. |
