Jacob
Maybe I missed it but why did you replace the intermediate shaft gears? I hadn't anyone doing that I recall. Jim |
no worries, i'll be there =)
-Vinny 1983 911SC |
beancounter
They were showing some wear. Perhaps they could be reused, but the new sprockets are not much $ in the grand scheme. I don't like the idea of new chains on old sprockets either. This was a "better safe than sorry" thing.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
beancounter
beancounter
Hello Gents
Putting the topend together and I have some questions about the cylinder cooling tins. For those who have been down this road, please have a look at the thread I started over on the engine rebuilding forum: Cylinder cooling tins - can I get a ruling? Gratuitous rebuild pics: ![]() ![]()
beancounter
Happy Valentine's Day dear!
Update...I bought a set of used 3.2 cylinder cooling tins to use instead of the originals. IMO this is necessary with the upgrade to fully finned cylinders. Too bad I didn't know in advance or I wouldn't have had my originals powder coated.
Yesterday I primed and painted the tins. I also spent a fair amount of time making sure that the cylinder height was even. Checking with a straight edge accross the deck, at first it appeared that one was short. I pulled the jugs up enough to put a vernier on them, measured multiple times and found them equal. Still with a straight edge one seemed lower. This was not making sense, so I bolted the heads on and put some torque on the nuts. Then I put my straight edge across the head to cam tower mating surface and everything looked perfectly even...good! The base shims must have been pushing the jugs up ever so slightly and making it look as if the cylinders were uneven. Today I made some good progress got the top-end bolted up... Camshaft housing and heads clean and ready on the bench ![]() Left bank completed ![]() Right bank going together ![]() looking like a flat six again ![]() here's her bottom
Turbo Hooligan
Lookin like a million bucks Jacob! can't wait to see what kind of numbers she lays down!
D-Zug ![]() |
Sweet Jacob! In the words of Borat, Veeerrrryyy Niiiiiice!
You are kinda on the 'home stretch' at this point. BTW, just curious as to why you went with ARP head bolts vs Supertec?
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
beancounter
ARPs are recommended by LN Engineering for use with Nickies cylinders on their website, although I've seen that Charles Navarro has also endorsed Supertec's stud here in the Pelican forums. I bought the P&Cs through Chris Carrol at Turbokraft who uses and recommends the Nickies cylinders. He also recommended the ARP hardware, so it was convenient for me to do everything in a single transaction.
beancounter
Bit by bit, putting it together. It was over 50 degrees today. Getting antsy to drive...
Looking good Kid.
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun ![]()
Jacob -- great work on the engine, and great photos.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
beancounter
meanwhile, back at the chassis...
...Been working on wiring up the new ignition system--->
Coil packs mounted and hooked up with wire harness ![]() Harness follows the A/C line and then through a new hole I bored in the firewall ![]() Inside the car...electronics are mounted underneath the passenger seat. That's the Electromotive ignition brain, and an Innovate DL-32 datalogger. The datalogger will hook up with my LC-1 wideband AFR, and I will be logging RPM, Boost, AFR, and CHT, plus it has a dual axis accelerometer. ![]() And finally at last the obligatory pic of me in the engine bay. If I look pissed off, its because I just spent the last 5 hours hunched over pulling wires, stripping insulation, soldering, etc in a 1 car garage with no electricity and no access to running water. My back is PISSED.
smile jacob, your almost there
-Vinny 1983 911SC |
Just keep thinking about how awesome all that new horsepower is gonna feel come summer. Besides, what else would u be doing, chores around the house or something equally useless???
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com Last edited by juicersr; 03-24-2010 at 08:42 PM.. |
Banned
saaweeeeeeeeeetaaaaaaaaaaaahhhhh on the DL-32! Schwing!
ditto for der rest 8-) stay focused - be the ball, Danny... fa na na na na naaaaaaaaaaa |
Very cool Jacob!!! That beast will be ready for the next Turbopalooza!!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Great updates! It'll be ready for spring.
The end is near, Jacob, hang in there! Good job on your project.
MikeD '87 930 |
Banned
