copbait73's Avatar
Please Identify K27 Turbo
Last spring I bought a 3.0L Turbo motor project.
The engine looks to be stock except for RoW exhaust and a newer configuration K-27 turbo having modern 3K rotor.
I ran the P/N by our own RarlyL8/Brian and he could not cross it.
The P/N: is 5327-999-0493.
A Google search had one hit identifying it as used on the 935 race car (in pairs).
Maybe that explains the "999" mid P/N designation.
Does anyone have knowledge of this being used on a 3.0L or 3.3L Turbo motor? If so, how does it compare with established K-27 configurations?
Old 11-22-2009, 04:27 PM
Turboo934's Avatar
It would help if you posted pictures, of the ID plate and turbo.
Old 11-22-2009, 04:36 PM
totle's Avatar
Found picture of 935 turbos with same part#
Old 11-23-2009, 03:25 AM
Crotchety Old Bastard
RarlyL8's Avatar
Where did you find that info Trond? I cannot find the "999" part number anywhere. My listing for 935 turbos does not include that number.
Any details?
Old 11-23-2009, 05:01 AM
copbait73's Avatar
This shot came from the website I found stating these are 935 turbos.
1 STUCK - Items of special interest
My turbo was in the orientation shown in the picture, turbo on the right.
The compressor impeller also has fine impact abrasion also typical of turbos run on racing installations.
Disassembling the end housings it's very obvious (from the as received orientation) this turbo was never actually run on the motor I received so I'm back to investigating it's suitability.
Compressor inlet is 52.5MM and turbine exducer is 64MM placing each in the ballpark however I'm not sure of the turbine area. The casting is marked 1.6. Placing this turbo in the 80s timeframe the housing may have been stated in area or A/R. If in area it would be OK. If in A/R this is a very large housing.
Research shows it supported 600-750HP (in pairs) on the 935 and used as a single 300-350HP is the top range for this 930 engine. Its standard K-27 outline so I'll just start with this one and see how it responds.
If unsuitable I'll find something else. Who knows, maybe it was the trick hot-rod set-up for 3.0Ls back in the mid 80s.....or not.
Old 11-24-2009, 08:32 AM
RarlyL8's Avatar
Are these the same housing and dimension as a typical K27? If so then using 2 of them would take up a huge space and add a lot of weight. If they support 350HP in pairs does this mean the one you have is only good for 175HP?? I must be confused because this does not seem a viable solution to reach 350HP.
Old 11-24-2009, 09:03 AM
copbait73's Avatar
Brian-
Thanks for this posting. I went back and clarified my posting.
Basically 300-350HP /turbo.
Old 11-24-2009, 10:26 AM
proffighter's Avatar
Any details?
I am not sure, have to check, but I am pretty sure my K27 has this "999" too. As far as I know it shows, that it is a reman turbo
Roland
930 Turbo '81 Too many modifications to list
Old 11-24-2009, 01:51 PM
RarlyL8's Avatar
That was my first guess, and what I told Marty early on. I've seen a lot of funky numbers that are made up by aftermarket vendors that create hybrid turbos. The numbers listed for Porsche K27 turbos is 720. Mercedes uses 888, no idea who uses 999.
Old 11-24-2009, 02:02 PM
copbait73's Avatar
I'll try to get a shot of the nametag as it looks to be right from the factory. My guess is "999" reflects a prototype and or racing configuration. (Garrett convention is to place an "X" on the P/N).
All the major castings show KKK designation. Nothing out of place with these.
Still would like to pin down the turbine housing area. The turbine housing casing carries P/N 5327-101-8393 (and the area "1.6" cast in the volute and under the P/N).
Old 11-24-2009, 02:33 PM
copbait73's Avatar
Here is a shot of the nametag. I've seen a lot of aftermarket relableling. This one looks right from the factory to me:
Old 11-24-2009, 03:07 PM
...no idea who uses 999.
At least this company, which done my turbo rebuilt uses 999:
E. Klaus AG Fahrzeugtechnik - 9200 Gossau
It's a well-known dealer for KKK, Borg Warner and Garrett here in Switzerland
So nothing about special racing whatever hybrid
PS I will make a pic of mine tomorrow...
Roland
Old 11-24-2009, 03:20 PM
I took your pic to photoshop to try and make it easier to see, but it's extremely low rez and pixelated. It falls apart if enhanced and sharpened anymore.
Old 11-24-2009, 03:37 PM
Well, I was wrong
Here is my tag:
Roland
Old 11-25-2009, 01:33 PM
copbait73's Avatar
Shows this K-27 cross referenced to Porsche 930 123 017 00. This is a valid sequence.
I emailed Turbochargers favorable from STK Turbo Technik requesting a cross reference. This site has lots of interesting turbo data. I'll report what they say.
In the meantime I went down and finished stabilizing this unit for storage. I'm also pulling some stings to get a modern Garrett.
Old 11-25-2009, 07:09 PM
RarlyL8's Avatar
Marty,
#959.123.017.00 is the P/N for one of the 1985-01 959/Group B turbos. The other is -18. (K26)
#911.123.015.00 is the P/N for the 1973-09 935 turbo. (EB 33K)
#930.123.015.00 is the P/N for the 1977-10 935 turbo. (K26)
None of those turbos are K27's. What is the numeric family/sequence?
Old 11-25-2009, 08:23 PM
copbait73's Avatar
Marty,
My reference was to 930.123.017.00 on link 1 STUCK - Items of special interest
Did you go there?
Old 11-25-2009, 09:26 PM
Registered Driver
Helmsy's Avatar
Still could be a reman turbo.
Also check turbo-product for a reference for original turbo numbers.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 11-26-2009, 02:54 AM
Manassas, VA
lucittm's Avatar
You may know this already, and if so don't shoot the messenger. The picture of the turbo nameplate that copbait posted does not have a part number. This is probably because it was an aftermarket item built for replacement. Here are the lines from top to bottom with the data from my 1991 965:
KUND NR = Customer (Part) Number – 930.123.013.04
GRÖSSE = Size – K27-3072GD11.11
ATL (Abgasturbolader) NR = Exhaust-Driven Turbocharger Number – 90 051 2724
AUSF (Ausführung) NR = Version Number – 5327 970 7200
I think the first part of the ATL NR is the year - in this case 1990.
I hope this helps,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 11-27-2009, 10:44 AM
Well here is another one from my 1979 turbo Alan Johnson upgraded in 1984 according to the records with that same number 5327 999 0493. recent oil scavenger failure resulted in turbo failure so soon off for rebuild. Also has some nicks on the turbine blades. Would be nice to know what it originally was designed for. Comments welcome
Anthony @ Voitureltd Bayside WI.
Old 12-19-2009, 05:31 PM
