Boost Freak
Maxx1's Avatar
930 engine swaps ... how hard is it to install a newer, higher HP engine? ....
.... in the 930 chassis? Do the newer turbo engines bolt up transmission wise and mount wise, or is there a lot of fab work needed? Any engine swap kits?
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 01-25-2010, 04:52 AM
tj930's Avatar
..Ask JBL930 (aka 'JBL9930')
Old 01-25-2010, 05:35 AM
Blackbird Pilot
Reaper930's Avatar
964 motor in mine...adjust the engine mounts forward 1.5" and my stuff bolted up with changes to the oiling system.
Look at about $9k for fitting the engine tins and doing it right not including the motor.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 01-25-2010, 07:43 AM
A930Rocket's Avatar
What's the reasoning behind a newer and maybe higher HP engine? You can get 400 RWHP out of a 3.3 CIS motor and more out of a EFI 3.3 motor. Seems that you would be adding to the cost of a good build.
Thoughts?
Old 01-25-2010, 04:41 PM
Infidel
JBL930's Avatar
I guess the only reason to do it would be if you came across an already built, high HP motor, and it would cost more to build your 930 engine to the same spec?
In my case my engine was blown, and i'd already thrown a fortune at it. I wanted twin turbo's, great EFI control, and plenty of easy tuning options... A 993 turbo engine fitted the bill, it was a mission to fit though, even fitting anything other than a 993 turbo box to it poses problems... It was worth it though!
A 964 chassis is much easier to work with!
In a perfect world you'd buy a spare 930 engine, have it built to whatever spec you want, whilst still having your car to go and enjoy. Then fit your newly built monster motor when it's ready
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 01-25-2010, 05:57 PM
Buy a later car and put the change in the bank. For what I have into my car I could seriously have bought a GT3RS with the reciepts to show and I recently suffered a broken valve, no contact just a failed exhaust valve.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 01-25-2010, 06:14 PM
A930Rocket's Avatar
Ouch! Sorry to hear that.
I hear ya on the cost. I must have $65k in mine with me doing all the work. Of course it was aover a period of years and easier to justify.
Old 01-25-2010, 09:17 PM
Infidel
JBL930's Avatar
Ouch Lincoln, sorry to hear that. These cars are a love affair though right, you don't count the cost of all the holidays, meals and prezzies you buy for your wife/girlfriend, it just gets spent and forgotten.. I'm not going to go through my bill folder, i just open it and put the next bill on the pile and then close it.
Maxx, it all depends on what you want from your car, what engine did you have in mind?
Jonathan.
Old 01-26-2010, 03:28 AM
The carnage was unreal...
Lincoln Phillip
Old 01-26-2010, 07:05 AM
Infidel
JBL930's Avatar
What's your plan Lincoln, rebuild bigger and better, or just get it back together?
I'm so glad i did a leak down on mine before i took it to VMax, major leak on one exhaust valve, and when it was stripped all of the exhaust valve guides were shot, i guess if the valves are bouncing around in a loose guide they will be more prone to break. Do you know what caused your one to let go?
Jonathan.
Old 01-26-2010, 07:18 AM
copbait73's Avatar
Sorry to hear of your engine failure.
I the early 70s I worked my way through school rebuilding air-cooled VW engines. Most failed from #3 exhaust valve failure. As you say the carnage is unbelievable. Usually a total long block and in the case of the turbo motor, often the turbo also.
Typically exhaust valves that fail in good engines do so from excessive CHT.
Look at what the factory did to control this situation, they limited the HP on air-cooled street motors. For racing band aids were applied like flat fans. At the extreme, high power density means very short life spans of critical components.
There may not be limits to your bank account but there are limits within the architecture of the machine.
Old 01-26-2010, 08:05 AM
Well the guides were in good shape this valve broke at the base of the valve. The Long block is intact but I need a new set of pistons & cylinders and of course all new valves intake and exhaust. The car is wicked fast, with gobs of torque so reliability is the main goal at this point.
Lincoln Phillip
Old 01-26-2010, 10:02 AM
copbait73's Avatar
Was your valve lift and valve train radical?
Old 01-26-2010, 02:53 PM
Not really running the typical cams for this sort of build, GT2 Evo cams, matching rockers, titanium performance development retainers etc, I just had a bad valve.
Lincoln Phillip
Old 01-26-2010, 03:35 PM
copbait73's Avatar
Yes, that can happen also. Parts quality isn't what it used to be.
You were fortunate that valve head didn't destroy the piston then dig around in the crank, rods, and case. Did the stub get shoved back into the combustion chamber?
Old 01-26-2010, 05:19 PM
Eye of the Toiger
matty74's Avatar
Yeah but older cars are heaps of fun and very satisfying
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 01-27-2010, 01:24 AM
onboost's Avatar
Linc, Sorry to hear!!
RGruppe #180
Old 01-27-2010, 09:54 AM
BoxsterGT's Avatar
Porsche Crest
JBL930-
Any photos or advice on the engine upgrade?
Friend w an 88 and a bad motor is asking/thinking of doing the same thing.
Len
Old 02-24-2010, 07:55 AM
Infidel
JBL930's Avatar
Hi Len
I've gone into as much detail as i can on THIS thread, most of the info is there, if there is anything else you would like to know just ask, either on my thread or this one
Jonathan.
Old 02-24-2010, 08:14 AM
