Opinions for o2 sensor location!
Doing a lot of fuel tuning work to a customers car(previously dyno'd near 450whp on cis) and installing an o2 sensor...The rear muffler appears modified for 2 tail pipes and not sure which brand??
Problem is i only have a 3 inch space before i enter the silencer box and i was informed by the customer that CO readings prior to me receiving car were somewhat different from each tailpipe!....
My opinion was to mount on the left hand pipe near exit of silencer box as i think it would probably get fried quickly just after the turbo before it enters the box..
Whats you guys opinions?
Although the weld looks pretty neat,this tail pipe may be added on to silencer box for cosmetic reasons????
And where i thought location may be best?
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 03-15-2010, 03:42 PM
mark houghton's Avatar
That's probably your best bet, though it's pretty close still to the turbo and may get fairly hot from radiant heat but most likely not hot enough to fry the sensor. You could also add a heat sink to it.
Your other option might be to intall the sensor in the oposite end exhaust pipe (passenger side), as close to the body of the muffler as possible to limit the affect of background ambient air affecting the reading. That's where I've installed my AFR gauge sensor and it seems to work fine.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 03-15-2010, 03:59 PM
I put mine where the yellow dot is, it works good there.
Seen people put it a little farther down the pipe so it's in front of the turbo bearing housing and it worked there too.
Alot of it depends where you want to mount the controller if it's an LC-1 because the bosch wideband oxygen sensor wire is only so long.
Old 03-15-2010, 04:32 PM
Happiest when Tinkering
gsmith660's Avatar
This is where the Innovate tech told me to put mine and use a 1 inch bung and also the heat wrap/shield.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 03-15-2010, 06:47 PM
Wo ist die Rennstrecke?
DonE's Avatar
Here is mine. Its about 3 in from the turbo, so no chance of ambient air backing into the pipe. Its been there for about 3 years now with no problems (Innovate system hooked up to my ECU). Hard to see, but its at the 12 o'clock position.
Old 03-15-2010, 07:07 PM
Thanks for responses so far!
Could be an option then if you have been using yours in so close a location to the turbo with no issues?
I roughly have the same 3 inch space where i could mount it as near to the silencer as possible,i am pretty sure that Zeitronix and innovate recommend at least 8 inch plus or so...Out of interest has anyone else had postive experiences with the same location as DonE?
Old 03-16-2010, 01:49 PM
beancounter
jwasbury's Avatar
Here's mine...also close to the turbo. Its been fine here for over a year including some very hot days (at last summer's turbopalooza track day at Carolina Motorsports Park was probably over 90 degrees ambient)
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 03-16-2010, 02:02 PM
Crotchety Old Bastard
RarlyL8's Avatar
All of my mufflers are produced with the O2 bung in the spot shown in Don's picture. I've have my O2 sensor in that spot for several years as well. You can use a heat sink if you think heat will be a problem.
Old 03-16-2010, 02:03 PM
Infidel
JBL930's Avatar
The stock location for the pre-cat sensor on a 993tt is also very close to the turbo, i don't see a problem with it. I'd go with the way Don and Brian are saying, otherwise you'll have a job getting good readings at idle
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 03-16-2010, 02:33 PM
Ok thats me decided then as nobody has seen issues being so closely mounted to turbo,as we know limited space with 930s exhaust set up!.
Old 03-16-2010, 03:12 PM
I disagree. My readings at idle are stable and accurate as far as I can tell. My sensor is buried about 11 inches back from the tip of the tail pipe around a curve. Even if it were off a little at idle, I couldn't care less since I'm much more interested in AFR's beyond idle when there's lots of exhaust velocity.
Now, if I were to install an O2 sensor that near to the tailpipe and expect it to accurately control a Lambda emissions system, then I might think differently.
Funny how there have been so many posts on this topic over the years, and it seems the verdict has now swung back to it being ok to mount sensors directly after the turbo. If I recall, anything much greater than 950 degrees F is the kiss of death for wideband sensors. Read Innovate's information on that.
Old 03-16-2010, 04:02 PM
Personally i would have liked it somewhere in between my yellow mark in top pictures and where DonE and Brian have it however we dont have much of an option with the 930 configiration shown above.....unlike my 964 turbo with cat bypass,i have sensor mounted 10 inches after turbo which is ideal.
I wouldnt have thought it would have lasted so long this close to the turbo but looks like these are more robust than we think!.....You can always re-cal sensor with innovate or purchase spare to check figures against once in a while if supicious with readings.
Old 03-16-2010, 04:16 PM
Infidel
JBL930's Avatar
If yours is 11 inches back and around a bend then i guess that's far enough. I've seen many sensors fitted just after the turbo, i'm told about 4 inches would be optimal, but i guess you just do what you can. If you go through a sensor every couple of years who cares? As long as it works well when it's working!
Me talking about the 993 sensors may be wrong anyway, as i think they are narrow band and maybe subject to different temp specs? But there are plenty of people with wide band sensors just after the turbos, and they have worked fine. I'd just run with it Stu, maybe think about a heat sink though
Jonathan.
Old 03-16-2010, 04:26 PM
Same as DonE and 'J', mounted at the 12 o'clock position. Going on 4 years now.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
That's cool. I stuck mine where it is because I just didn't want to risk it after hearing too many negative experiences. Guess that there are as many non-issue experieinces out there as well!
To your point....whatever works. I'm good with that always!
Old 03-16-2010, 06:34 PM
RarlyL8's Avatar
Having the O2 sensor as close to the turbo as with my mufflers is not optimal for sensor life. I always suggest a heat sink for those who leave the O2 sensor in permanently, especially track cars. O2 heat sinks are not expensive and widly used in other applications. Mine has been in several years as well but the car sees no track time anymore so it is easy on the heat/sensor.
Old 03-16-2010, 09:11 PM
Turbofrog
smurfbus's Avatar
On my V-twin 1060cc bike it gets so hot (lots of sensor errors) I had to rig up a huge heat sink even at 10in from the exhaust port and there is no turbo so I would use a heat sink definately so close to the turbo. The older innovate firmvare version was not so critical of the extra heat so some have downgraded back to that older firmware. That means the readings are not so accurate than with the newer firmvare, but still more accurate than the competitors that have no correction over sensor life.
Old 03-16-2010, 09:30 PM
DonE's Avatar
The O2 sensor can take a fair amount of heat, but as someone said, if you're concerned, make a heat sink. In a Bosch article I read a couple of years ago, an O2 sensor really doesn't start working well until exhaust gas temps hit 1000 degrees (heated units help get the temps up early for accurate readings). The heat from the turbo doesn't even get hot enough to burn the shrink wrap on the wiring, which is closer to the turbo than the actual unit.
Old 03-17-2010, 07:47 PM
O2S Position
Mine's in same location as DonE's, J's, and WinRice and I agree with Bodart's opinion. Mine's at 10:00 and I'm using Innovate's $90 heat sink. No probs after 3 years.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 03-18-2010, 11:44 AM
16Volt's Avatar
Dredging this thread back from the grave since there is some good info here.
I have B&B headers and a B&B exhaust. The current O2 location is right before the turbo:
From what I am reading here the general consensus is that a WB O2 unit should be placed after the turbo. After doing some reading it seems that using the location before the turbo isnt going to work for a WB unit (most site back-pressure affecting the readings which makes sense). All the turbo cars I have owned/built always run the WB in the downpipe after the turbo as well.
So the next question is do I have the exhaust pulled and bung put in right before the muffler as Brian does or do I go for after the muffler in one of the tailpipes (likely driver-side).
As I understand it heat could be a problem with before the muffler and ambient air/moisture an issue in the tailpipe. Seems to me that running it before the muffler with a heatsink is the best option. What do you folks say?
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 04-09-2014, 08:14 AM
