Engine started to "puff"
I have just barely driven my car after engine rebuild.
Yesterday I went for a small drive to measure AFR. The engine stated to jump, got fire from the exhaust and died. I found that the wire between distributor and coil, was loose since I there was a spark to ground spark wires on distributor I hooked up the wire and the car started but was running poorly. Today I have tried to figure out what is wrong. Ignition is correct, but when misfires, it jumps between Z1 (TDC) and 10 degrees. I measured the pick-up in distributor since I was not sure if this was destroyed to to spark from coil on spark plug wires. It was measured to 650 ohm, so I guess this is all working. I removed all the plugs and 5 of them was dry (little to black, but running too rich) The spark plug on cylinder 1 was wet ![]() I checked and verified that there was spark on this spark plug. Tomorrow I will do a compression test on cyl #1 Please help with suggestions, running out of ideas now ![]() Next I'm thinking loose rocker arm, exhaust side?? Not a good video, but might give you a clue. The "puff" you hear is air coming back and out intake manifild
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo Last edited by totle; 05-08-2010 at 11:59 AM.. |
Forced Induction Junkie
Are you sure you don't have the distributor 180* out or spark plug leads incorrect?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I went over the spark wires and the orders are correct.
When installing the distributor I installed with cyl 1 in TDC, so should be good. Also the car was running well 2 days ago |
For fun, you might try swapping out the fuel pump relays with two known good ones. The black ones will work for the test. I had a red relay go bad that controlled the front pump and my engine sounded similar to yours..... almost like I had a major engine fault. As soon as I tried accelerating the engine, it died. Relay solved the problem.
But there was only 1 spark plug that was wet.
This would not happen if fuel pump was bad |
But the other 5 were sooty. It was just an idea. It is a lot easier swapping in a couple of relays than removing a valve cover.
I just can't see an engine running fine one day and then started up a couple of days later, the exhaust rocker is loose. IMO, of course.
This would not happen if fuel pump was bad I guess |
Going to Germany the 23'rd to Nurburgring.
Need to have my car ready soon to drive and test it out before i go
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
You probably already did this but check all fuses especially in the engine bay.
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
To do the spark plugs you took off the intercooler.
I would look for somthing that is making for an intake air leak and check the intercooler O ring did not get pinched. If that dose not do it then put the CIS gauge on it and check the system and warm control pressures. |
Let's start with the basics and do some very easy tests.
Unplug the green connector on top of the fuel distributor shown in the photo. DO NOT PRESS ON THE METERING PLATE as this could hydro-lock your engine with fuel........very bad. Turn the ignition key to "On" and listen for the fuel pumps in the front of the car and at the left rear wheel well. After you've confirmed the fuel pumps are running, turn the ignition switch to "off" and reconnect the plug on the fuel distributor. You mentioned that you got a fire out the exhaust pipe which makes me suspect the engine is being put in an over rich condition.
YES, found the fault today.
Turned out that the plug I had made to block the whole where the AAV had been, had blown out. I was so focused on checking ignition, that I forgot looking for air leaks. It was when a friend came over he saw a fire ball coming from the hose I now have used a better plug and glued and sealed the whole. Here is a picture showing what I mean ![]() I am still running too rich. Is it only the CO adjuster to adjust to make it more lean? What would a typical idle AFR be at?
Crotchety Old Bastard
Fireball? That's a new one.
I block that port with a large pipe plug and worm clamp. Idle is 13.5:1 AFR / 3% CO. Yes mixture adjust screw does this function. I notice that the oil breather hose hard line is not secured to the intake bolt but rather sitting on top. Engine is really clean! Nice!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brian, picture was taken of the engine before it was put back in. It is secured:-)
Tinkering Pays!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Tinkering Pays!!
Now, this is only for idle mixture adjustments...
Yes it's on a stand as the throttle cable is not connected. The heads up on the tube was to get that fixed before the engine goes in. Ask me how I know, ha!
As it was getting spark and fuel I thought it sounded like a leak in the intake tract but never would have guessed that one.
What get's me is the plugs were sooty and wet, the engine ran(barely) in the video posted above, with that big air leak in the intake tract. It really shouldn't of started at all or started and immediately stopped.
Something still isn't right with this engine.
It might have been ignition issue as well.
I removed distributor cap and checked. Re-ired the spark wires. Adjusted AFR today from 9 to 13,5 at idle. Engine is running fine at idle and boost. Will log AFR now. One strange thing I noticed today was that when accelerating in a turn, left or right, it seems like engine is loosing ignition or fuel, and stuttering and ends with a bang in the exhaust. When accelerating straightforward all is well |
