Crotchety Old Bastard
My 930 headers are already setup for twin scroll as the banks are divided all the way to the turbo.
If you wish to go further and eliminate the shared wastegate path we have a dual 38mm waste gate option, one for each bank. I might be interested in your headers and turbos if you want to do a little horse trading. ![]()
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Just to let the cat out of the bag, Brian built me a set of 1 5/8" equal length headers, with a 'kit of parts' for the secondaries so I could do the final fit with a twin-scroll GT4088R. He also sent me the parts for the twin 38mm waste gates.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Infidel
put the crack pipe down......
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan ![]() |
R.I.P.
Brian, I have a buddy interested in the headers but if for some reason he does not want them we can definately talk. I'll PM you
R.I.P.
well hell man, let that cat out. 4088 huh? whats your combo? I have seen the 4088 mentioned before and i'm all ears. I did notice in the pic that flange was a T4 |
Here's the basics: 1 5/8" equal length primary and secondary headers to a GT4088R (sitting on the shelf) Dual 38mm wastegates (have to on a twin scroll) (sitting on the shelf) Extrude honed Carrera intake with a 75mm accufab throttle body (sitting on the shelf) 72 lb/hr Siemens Injectors M&W Ignition Probably Link Extreme G4 ECU Custom cams, close to a GT2 EVO grind Extreme heads porting, head work and dual plug. Probably JB Racing 98mm Cylinders with custom pistons R&R rods from LN Engineering Custom full bay, cross-flow IC I picked the GT4088R for a couple of reasons, I wanted the twin scroll for better spoolup, and I wanted the bigger compressor to run the higher pressure ratio I need at my altitude of 6000 feet so I can get closer to the power you guys get at sea level.
R.I.P.
looks like a deadly combo. The 4088 may be slightly large for my stock little 3.3 and since my company recently became a Bullseye distributor i'm eyeballing their S262 small cover turbo. So many choices
Yep, might be a little big for your combo. I'm going for 500+ rear wheel at 6000 ft altitude. We'll see if I make it
![]() Either way, I think a twin-scroll is in your future. ![]()
R.I.P.
Twin scroll is definately in my future. The car is going on the lift tomorrow so we can decide which headers will work best. Gotta order my KEP pressure plate too.
Here is a better picture of the Y-assembly plenum on the 930 headers. This is the standard 930 T3 flange.
That absolutely puts my GSF to shame and they were better than the OBX. Superbly done, Brian.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Thank you but I only designed them, Ben is the weldmeister.
Stepping up to a T4 is somthing to consider for a big HP buld as it has a much larger volume potental. With most T3 header's the volume change from the secondaries to the turbo inlet is quite agressive. Not so much w the T. I forget but it is like 3.5 v 5.5 sq in.
Probably not a big deal for most. |
R.I.P.
here are some updates to my project
R.I.P.
and more....
R.I.P.
The intercooler cores are a pair of Bell Intercooler 12 x 8 x 3" 660cfm units.
Nice progress!
Wish I could get to that point.
R.I.P.
wait till you see the fan and shroud. They just came back from powder coating
R.I.P.
and the cooler is fully welded. Just needs some support brackets and off to powder coating.
![]() All one piece. Only needs a connection at the turbo outlet and the throttlebody entrance. ![]() and here is the fan and shroud after a healthy coating of powder coating. The black looks wet still, awesome job Fuzion PowderCoating.. ![]() |
Thread Tools | |
Rate This Thread | |
