UNDER CONSTRUCTION!
strange knock from engine need some help with diagnostic
hey guys
i took the 930 out for a drive and while at a stop sign i noticed a strange knock!! this only occurs when you blip the throttle to about 2k rpms and while its dropping back to idle if you just touch the throttle to stop the rpms from dropping you get a single knock. this only happens at low rpms, the car has good oil pressure at idle and runs 5 bar at 3-4k on the dash gauge. there is no knocking under load and non under .5 bar boost as i was afraid to boost any higher till i find the knock. this knock may have been here a long time because its very heard to here unless you know what your listening to. while behind the car with my chest on the intercooler with my left hand operating the throttle i can feel the knock on my chest, it feels like a valve opening and closing when it happens. i cant determine what area of the motor its coming from maybe right side. was thinking chain slap from the chain case area but just not sure.any ideas? cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Before I got my 3.3L Turbo engine, my 911 was a "standard" 911, with a normal 3.0L
One day at the stop light I heard a thump-thump-thump...WTF? I didn't know it, but I spun a bearing at the crank. I highly recommend not driving it anymore until someone in the know can actually hear what the problem is...it could be something as "small" as the fan housing/alternator going south, or loose, or something much more major. Good luck!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!) 1996 Toyota Corolla(der 'clapper') |
Ed, are you running the standard "short neck" intercooler configuration? It "may" be the stock recirc valve gaskets. Check here: Changing 930 dump-gaskets, pictures galore
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
UNDER CONSTRUCTION!
Hey RSR
Yes standard short neck ![]() great link and think that must be what I'm hearing. Do you know if it only happens low in the rpm band ? I went out and played with it somemore and when I first crank it I here the knock one time, then I here it when I step on the throttle and maybe when I lift but the muffler is loud. My car has about 40 k miles and has sat a large part of it's life. I will put a stethescope on that area and hope that's the sound. Quote:
UNDER CONSTRUCTION!
This isn't your nomal knock it's a single knock like a valve closing or opening? I think RSR hit it on the head. I'm crossing my fingers on this.
Hello there,
Mine had a similar sound, it would show up every time I blipped the throttle aggressively from idle while in neutral. Kinda a thunk or clack sound. I bought the new gaskets to fix it from our host (dirt cheap by the way). I went to replace them, only to find that the job is super simple & fast to do. Pop off the intercooler, pop off the top section of the intake (3 bolts, several hoses, couple of wires). Take off the 8 little nuts on the cover plates(watch out for the spring tension it's pretty high) and there are the offending gaskets. In the end, I simply changed out the gaskets and the noise went away, and then decided to completely dead end the whole system, but that's another story. Mark |
UNDER CONSTRUCTION!
well ill order the gaskets and swap them out and see what happens,
i have read a little about eliminating this unit from the engine,if so what type of valves are you guys running and what can i expect from a different unit or type. i have a larger intercooler but its the short type to bolt on a factory motor. should i just replace the gaskets and be happy or should i go another route? cheers ed
Hi Ed. Sorry that I cannot be of any more help regarding the RPMs... I am running a factor C2 turbo intercooler and have upgraded to the Forge Motorsports diverter valve. I bought the car with an Andial longneck intercooler so I cannot offer any comparison between the characteristics between long and shortneck.
The 965 setup uses a tiny plastic Bosch recirculation valve instead of that magnesium housing - although at least some people hold the Bosch part in their hand for less than a minute before they head for the nearest web browser and buy a billet replacement instead (rebuildable, tunable). (The plastic Bosch valves don't have the best reputation for reliability - but are also factory fitment on SEATs, Audi's and probably some VW's - so the aftermarket is knee deep in better made alternatives.)
'77 S with '78 930 power and a few other things. |
It is the stock recirculation valve internal piston slamming against it's stop. Put new gaskets in and be done with it.
Every time you get off the throttle, engine vacuum will pull and hold the piston open until you get back on the throttle and vacuum goes away. Thus, quick throttle punches in neutral will produce this sound. Fix it, or don't worry about it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Porschaholic
I experienced something similar... I'm going with the BOV valve... nothing worse than a cool car and that stupid "knock"
Martin B Orange County, CA. 1986 930 Meteor Grey Yes it's fast... and no you can't drive it! |
Crotchety Old Bastard
That's the first thing that came to my mind as well. Common issue. The sound should be a metalic click, and as others have said will be most pronounced during a snap throttle at low rpm.
If you wish to keep your present intercooler you can add a 965 BOV by making an adapter out of your 930 BOV. There are a few threads on that.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
UNDER CONSTRUCTION!
brian
i just purchased a larger intercooler so the adapter seems like the way to go. by the pic you posted looks like the stock one has been cut and welded up. ill do a search and see what i can find. im sure know after more diagnostics that it is the stock bov makeing the single clank sound. thanks guys. cheers ed
Please don't flame me for the less-than-professional hack and glue job I did on the magnesium parts. It's temporary until I can find someone who welds magnesium. So far, it's holding up just fine though.
Ed,
PM "The Gimp" alias Mark Houghton. He happens to be the man in the know when it comes to this procedure. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
UNDER CONSTRUCTION!
hey guys thanks for all the help. ill p.m. mark and see what i can come up with. should these parts be welded? seam s like heat cycles would eventualy break down the epoxy!
cheers ed
Hey, maybe I can claim some extraordinary glue performance linked to Turbo Porsches and get JB Weld to send me a lifetime supply of their stuff
