exc911ence's Avatar
Running a 3.3 Turbo without an intercooler. Possible?
I recently read a magazine article about a mid-year 911 like mine, but with a 3.0 Turbo engine shoehorned in. Being non-intercooled, it fit well under the stock engine lid but it got me wondering if the 3.3 unit could be used in the same application without its intercooler. Of course there would be a horsepower deficit in doing so but even slightly neutered, it would be an improvement over a stock 2.7L.
Thoughts?
1979 911SC "Frankencab"
Dave
Old 09-20-2011, 05:15 AM
DSPTurtle's Avatar
The first turbos had no intercooler. Yes, it can be done and was done by the factory... back in the day.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-20-2011, 05:44 AM
After the next project
x98boardwell's Avatar
Not the best formula for trying to cool down the forced air into the motor but DSPTurtle is right. You could always do no IC and then add air/meth injection (I think I'm saying this right)... it would cool down the air significantly almost like a IC. You would just need to refill the tank along with the fuel.
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 09-20-2011, 07:18 AM
Smart quod bastardus
fredmeister's Avatar
I think you could make up for the loss of intercooler by running a water meth injection kit. This would be a great way to keep from running lean and cool your intake charge down tremendously. I like the Snow Performance kit on my 79 930 turbo.
Cole wrote up a great article here on his set up, which inspired me to install the kit.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-20-2011, 07:19 AM
race911turbo's Avatar
Yes it would work, you will get faster turbo respond but less HP at high end.
1975 914, 1988 944 turbo S sold.
1986 944 turbo resleeve 2.7, DTA S-60 PRO.
1986 911 Carrera with 965 turbo motor, DTA S-80 PRO.
1989 930 EFI, DTA, Carrera intake, twinturbo,2x GT-35R.
1991 964 convertible, wide body conversion.
Old 09-20-2011, 08:02 AM
Max Sluiter
Flieger's Avatar
How about an expansion manifold like the new GT2RS? If the turbo is big enough to activate the wastegate then there is "excess" boost that can be put to use by compressing the air more than needed, then expanding it again and cooling it a bit in the process? This could just be a small tube tapering into a large tube.
Old 09-20-2011, 09:51 AM
Ollies930's Avatar
How about an intercooler in the left rear fenderwell? I believe several members here have done that with good success.
Old 09-20-2011, 10:43 AM
totle's Avatar
There is also some that have modified the stock IC to make it fit under the lid with no wing
Someone made a thread about it in this forum
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 09-20-2011, 01:56 PM
totle's Avatar
found some
No silly wing INTERCOOLER project
pics wanted intercooler under lid
Intercooler vs. No Intercooler
Trond R.
1986 944 Turbo
Old 09-20-2011, 01:59 PM
exc911ence's Avatar
Thanks for the replies and various ideas! This is only a pie-in-the-sky plan at the moment since my 2.7L is still running like a racehorse, but it can't last forever!
Dave
Old 09-20-2011, 06:22 PM
Possible does not equal advisable
Old 09-20-2011, 06:52 PM
Tilikum Turbo's Avatar
The original 930 3.0 was non-intercooled(but the engine was designed from the get-go not to need one(hence the difference in about 50HP, down from 282 to 234HP(of course the 3.2L crank and the .1L displacment didn't hurt the 3.3L either).
As far as the original plan of a non-intercooled, non-turbo 3.0L, then turbocharging that motor with no intercooler.
These engines are very tricky that experimenting with the route you are thinking and could hole pistons or much worse. Sounds like a major headache project.
If I were to go the 3.0L turbo route, then I would find a true 3.0 turbo engine from a 1975-77 930. This way...NO surprises if it's tight from the start, or it your a DIY'er, then rebuild the engine.
As far as neutering a 3.3L with no intercooler...absolutely not.
Good luck!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-20-2011, 10:25 PM
Crotchety Old Bastard
RarlyL8's Avatar
The 3.0L 930 engine is a half point lower compression than the 3.3L 930 engine. Many ways to compensate: run best fuel or lower timing on boost or lower boost level to 0.6bar or add a small intercooler under the duck or add H2O/MeOH injection, or etc. etc. The 3.3L intercooler is not the best so easy to compensate.
Old 09-21-2011, 04:40 AM
R.I.P.
drmatera's Avatar
yes, and I would go with a WMI kit before trying to make an intercooler fit under a stock lid. Besides the cooling effect there is also an octane benefit
Old 09-21-2011, 10:57 AM
