Weird “click” noise…
I have a ’89 930 and when I blip the throttle there is a sound I can only describe as a “click”. You hear when you accelerate and when you lift off the gas. I seems to be coming from the engine compartment, driver’s side, maybe a relay or sensor??
Old 04-05-2012, 06:25 AM
full quack's Avatar
Send a message via Yahoo to full quack
That's an easy one, you need new seals in the by-pass valve in the lower intake manifold. The seals are available from our host, they are cheap & it's an easy D.I.Y. job.
Mark
Old 04-05-2012, 06:28 AM
Banned
Here you go:
Changing 930 dump-gaskets, pictures galore
Old 04-05-2012, 06:44 AM
89 930.
Benny771's Avatar
Just wondering, what if you dont change them ? Whats the disadvantage ?
Old 04-05-2012, 07:14 AM
Wayah Road Warrior
Shadetree930's Avatar
Result is tell-tale "clonk-clonk" sound when you step on the throttle, bad idle, slow boost buildup etc. They are cheap and can be changed in two hours by any home-mechanic like me and you.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 04-05-2012, 08:00 AM
Crotchety Old Bastard
RarlyL8's Avatar
The "gaskets" are a plyable waxy material that disintegrate after years of heat and use. As this occurs the engine is digesting the material. Once it is gone the piston hits the housing metal to metal and there is also the likelihood that the piston will become lodged in the bore by pieces of the deteriorated gasket. With no gasket you now have no seal which is a vacuum leak that will manifest itself as a raised idle. All this leads to an ill-performing engine.
Replacing these 2 gaskets is about as easy as changing your oil. Allow a couple hours for the job which should include inspecting everything while the BOV is out and replacing all of your rubber hoses while you are in there.
Old 04-05-2012, 09:52 AM
When you remove the 10mm nuts holding the ends on hold onto it or the spring pressure will launch the piston.
Old 04-05-2012, 10:01 AM
Guess what I'm doing this weekend?
Thanks guys.
Old 04-05-2012, 12:56 PM
...I'm back, any help on the part numbers would greatly be appreciated.
There's a lot of parts and o-rings that all look the same.
Thanks again.
Old 04-05-2012, 01:26 PM
full quack's Avatar
Here you go, 930-110-149-00-M17 you will need 2ea. $3.50 each from our host.
Mark
Old 04-05-2012, 01:48 PM
