89 930.
seems to be leaking....... Is that a "regular" part to replace
89 930.
Banned
Is that the oil line going to the cam chain tensioner (hard to tell from the pic)?
89 930.
Nope, its electrical...... drivers side, behind the up-pipe, goes into the chain cover.
![]() 89, 930 |
Banned
Then that would be the thermo time switch - only electrical component on that chain box cover.
83 911 Production Cab #10
Hopefully its the seal...
From the 83 PET (not sure what is your year) Thermotime Switch on chain cover, 911 (1974-83), 911 Turbo (1976-85) #30: 911 617 117 Temperature Switch $203.25 Pelican Parts - Automotive Parts and Accessories - Porsche & BMW #31: 900 123 007 Seal $2.25 Pelican Parts - Automotive Parts and Accessories - Porsche & BMW ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
89 930.
May be a silly question but is there one on each side? I think it may be # 30 in the picture.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-617-118-00-OEM&catalog_description=Temperature%20Sensor%2C%20%39% 31%31%20Turbo%20%28%31%39%38%36%2D%38%39%29%20 Last edited by Benny771; 06-03-2012 at 09:22 AM.. |
Banned
It is #30. In the 86 Cat they got call out # for both side but only lists the driver side and if you look at the PP info it says 1 per car. Mine is fitted Oil Breather Cover Hopefully a change of O ring will do the trick.
You have to match it to the engine type.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 06-03-2012 at 09:56 AM.. |
Benny
Since you got an 89 Turbo, it would be 930-617-118-00 (link in Ronnie's.930 post below). Of course since its a Turbo... Its more expensive $283.75
89 930.
Thanks for the info guy's. Do these things start to leak at the connector like my oil pressure switch did?
Start with the O ring... If you got a local Porsche dealer, they would have it in days and price would be the same (discounted under the new Classic pricing.
Thread Tools | |
Rate This Thread | |
