changing spark plugs
Changing plugs in a 930 is like learning a new language, You will learn the 4 letter words first and quickly !! LOL
Anybody have an easier way for the drivers side plugs
The Porsche spark plug tool works pretty good, still very challenging to work in such a confined area, maybe someone has a better idea ?
1978 930 Eurocar, steel slant. k27HS, Powerhaus IC, SC cams, RarelyL8 muffler.....,
2002 Mercedes CLK55 AMG Cab, chipped,
Previous and dearly missed:
1965 911S, 1970 911T, 1974 911S, 1978 930, 1982 930, 1950 Mercedes 300, 1988 Mercedes 560 SEC Convertible
Old 10-14-2012, 11:11 AM
Without dropping/lowering the engine, the OEM spark plug tool is the way to go.
Old 10-14-2012, 11:22 AM
Crotchety Old Bastard
RarlyL8's Avatar
Cyl #1 is a nightmare if you haven't done it a few times. Many times I have changed plugs for others only to find #1 had apparently not been changed during recent tune-ups.
What I use is a 3/8 ratchet, 3" extention, spring wrapped wobble joint, and spark plug socket.
To get to #1 I remove the 930 BOV. If you have a 965 BOV this is cake.
Old 10-14-2012, 11:28 AM
jsveb's Avatar
I went to Sears and bought one of their spark plug sockets.
I tape the extender to the socket, and seat that on the plug before engaging the ratchet.
Four letter words a little blood etc - sure, but not too bad.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 10-14-2012, 11:47 AM
Ken911's Avatar
i remove the two back motor mount bolts and lower the engine a fe inches then do it from the bottom. easy and doesnt take long.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-14-2012, 12:22 PM
full quack's Avatar
Send a message via Yahoo to full quack
I simply use a spark plug socket that has a built in universal joint on it, then a 6" extension and a 3/8" ratchet handle, works out ok. I do not remove anything except the intercooler, up pipe & fuse panel cover.
Albeit, sometimes you do bleed a tad bit in the process.
Mark
Old 10-14-2012, 06:04 PM
BlkBird's Avatar
Nothing in here about a magic wand? I am not looking forward to the three driver's side plugs at all!
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 09-20-2013, 12:30 PM
Tilikum Turbo's Avatar
Possible to still do this on a car with the smog pump, etc still intact without lowering the engine?
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-20-2013, 03:34 PM
Chris piece of cake....
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 09-21-2013, 07:26 AM
Hymn I usually struggle with this sort of thing but the plugs were cake for me. I have a pivoting ratchet and a wobble extension that seemed to be the perfect length. The hardest part for me was the plug socket got stuck on the plug a few times
18 Cayman GTS
Old 09-21-2013, 11:45 AM
BlkBird's Avatar
Removed intercooler and the 965 BOV. 1/2" ratchet and an extension with a deep socket. Curse the 800lb gorilla that put the plugs in last time. Curse louder. Plugs came lose. Change over to a 3/8" drive with a real sparkplug socket that holds the plug snuggly.
The rest was pretty easy.
C.H.
Old 10-01-2013, 12:37 PM
xbmwguy's Avatar
its always the driver side! and when you have 12 i gotta remove the wastegate too damn #1
Old 10-01-2013, 05:25 PM
Chain fence eating turbo
I hate to rub it in but on my turbocharged Carrera 3.2, I don't remove anything to change plugs and it's not bad at all. About 30 minutes to do them all.
No AC or heat though.
Old 10-01-2013, 05:38 PM
T77911S's Avatar
thats what i use except mine is not spring loaded.
i recently welded it all together since the socket would sometimes come off when piutting plugs back in unless i put the plug on the edge of the socket.
i dont know what your configuration is but when i did a leak down test, i loosened the turbo inlet tube at the turbo so i could move it just enough to make it easier to get to #1.
very dumb question, i do hope you are taking the IC off.
i changed plugs on a friends older toyota min van. the engine is under the car and lays on its side. very neat, low center of gravity. but to get on e of the plugs out. you have to drop one end of the motor down. it is OOOH so close to coming out, but just not quite.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-02-2013, 04:39 AM
