sudo apt-get purge 930
Researching EFI, have questions
So I'm starting to do some research on EFI systems. Needless to say I'm
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Kartoffelkopf
Mark, hi....this sounds like an echo of my opening gambit, some 15/16 months ago
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
I opted for MS-3 there are quite few people here who are do it your self types who have went to mega sqirt. If you plan on having a shop do it then use the system that shop is familiar with.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Forced Induction Junkie
Mark,
Have you looked into EFI University? They have a forum which could provide you with starting points. http://www.efi101.com/index.html
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I've been looking at Megasquirt. I'm not afraid of DIY. I just wasn't sure if it was a good system. I am hoping for people with hands on with it.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey Last edited by equality72521; 12-26-2012 at 04:32 PM.. |
Edited due to misunderstanding on my part.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey Last edited by equality72521; 12-28-2012 at 12:37 PM.. |
I would think the least expensive choice if you are going to do it completely yourself would be MS2 with an EDIS ignition which would give you batch injection with wasted spark ignition. You would need fuel rails with injector adapters (?TurboKraft), a fuel pressure regulator, a crank pulley with 36-1 toothed wheel with Ford VR sensor/mount, an EDIS-6 controller, an EDIS-6 coil pack with spark plug wires, assorted sensors (throttle position sensor, coolant temperature, intake air temperature), and appropriately sized fuel injectors.
Sequential spark and ignition could be done with MS3/MS3X with the addition of a cam sensor and appropriate increase in number of coils, cost, and complexity of wiring harness. If you are going to have someone else tune the car, I would highly recommend using whatever system they are used to.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
R.I.P.
Yes MS2 with EDIS is the way to go. If you have a shop build and tune the system you will be helpless and need to rely on them for any tweaks or upgraded. That cost more money down the road. Install and learn the system, trust me if you are a hands on guy you'll love it.
Chain fence eating turbo
I have MS2 and EDIS too. Since I already had a Carrera 3.2, it only cost about ~$1500 to convert. |
I look forward to seeing the responses to the OP questions.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
non-whiner
What about Electromotive? I've used there TEC on several cars now and am now trying it on my first Porsche. My first attempt at EFI was with a Weber Redline 882 on a 450HP Ford V8. The TEC is light years ahead, but is the MS2 with EDIS that much better or is it more cost efficient given the application?
"Too much is just enough." |
Cost efficient
Happiest when Tinkering
I started with MS 1 and immediately went MS Extra and now because I have additional requirements I just upgraded to MS 3 and love the versatility although the tuning has become a chore because my MS Extra tune didn't really transfer well. Recommend it for sure and you can go either coil on plug or EDIS with MS 3
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
R.I.P.
Unless you really just want to spend more money |
Metal Guru
My concern with EFI is re-sale-ability.
It seems that an converted car's target audience gets narrowed to the guys that hang out here at PP. Someone that can't or doesn't want to tune his own car won't want a car converted with MS. Then you have to consider how many professional wrenches have dealt with MS. In a way, I think that a Motec conversion addresses these concerns better only because there are more shops that have dealt with Motec than MS. Motec is very popular with the track car crowd so it seems to reason that there are more shops that would be familiar with it than MS. The drawback is the high cost of a Motec conversion. Having said that, I am pro-EFI but just a little hesitant to take the plunge for the reasons stated above.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I suggest VEMS! more features, has more display (and apps) options and integrated hardware in box (e.g. Wide band, map sensor etc.) than many of the most expensive brands, most cost efficient setup. One of the most used box and software on internationally tuning/racing/drag forums, so getting help etc. on forums, comparing log-files etc. makes it easy.
locally in Europe it can be purchased for 1000$ with all you can through at it. A 930 1000$ setup could be: besides all general features among units then on top includes dual WB built in the box, 400kp map sensor built in, the list of features is endless but to name some of the most used e-boost control, boost per gear/rpm, sequentiel fuel/ignition (6 or 12 COP), 2 x knock control, 2 x WB, 2 x EGT, etc. no other ECU to my knowledge offer that many feature without being ridicules expensive. look up a price for a dual wide band unit hardware and map sensor and it would cost more alone than the complete vems unit. a ready made 6 cyl box loom can be purchased for about 350$ including all relays attached and connected. The price is not the strength in my opinion, it is the many display/dash options I like most. you can get a display/dash that is programable to display 2 output at the same time (e.g. AFR vs. EGT or RPM vs. temp or boost vs. gear etc.), it should fit in the dashboard, it has a button, push and you pick from 8x2 outputs (8x2 as I recall). Price 200$. Also big displays available, or android app. look on youtube for tutorials. there are also 930 vems conversion on this forum |
Thanks guys! I was leaning towards MS and EDIS but wanted to hear from you guys that have done installs for first hand feedback. Now time to start reading all of the MS documentation. I really didn't want to read ALL documentation for ALL systems so thanks a bunch.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey Last edited by equality72521; 12-28-2012 at 12:38 PM.. |
Maybe you should just figure it out yourself. |
R.I.P.
Ultimately if you bought your 930 to sell it why do anything to it? Every penny you put into it is lost, then pile on insurance every year, tires, tune ups, engine rebuilds, gas etc... and you are better off giving Burnie Madoff a go with your money. |
Thread Tools | |
Rate This Thread | |
