I would rather be driving
No problem on the questions. There are many that do not understand EFI installations and converting while mix and matching various systems and components.
Jesper, Yes, this could be an easy way to run a secondary injector setup. I am not sure if the Carrera manifold would clear the rear deck with an intercooler when mounted on top of some blocks. Maybe if you cut and rotated the throttle body. But then you are doing enough custom work you might as well weld some bungs in place. The idea for this adapter is to make EFI integration as simple as possible with as little hardware changes as possible. Thanks for the compliment.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
This is a great solution. I was wondering if anyone has ever attempted this.
Are the existing brass fittings pressed out or just drilled larger to accept the bung? Is it better to go with 11mm bung or 14mm bung. Guess it depends on type of injector to be used.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. Last edited by jpilcher; 02-22-2013 at 03:20 AM.. |
Crap, and I just sold my spare set to speedy! Oh well....
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Ingenieur
JCC911, now you made me feel bad! If it is any consolation, yours are staying stock. I kept all my other stock stuff in the event a stock 930 becomes stratospherically valuable some day.
By the way JCC911's blocks have cracks (which he of course told me about before the deal), so that, plus Chris' comments re-affirm my statement not to bore them out. |
Either method could be used. My adapter allows for easy home installation. Not many people have the expensive step drill bit to recess the injector as Speedy Squirrel did. I do have this bit for making fuel rails. If you would like some help in that direction let me know.
These are finally back from the platers. Ready for an engine near you.
Chain fence eating turbo
Looks good Jamie! Can't wait to hear someone use these.
Where do I sign up?
With the flow rates of modern injectors, and a modern ECU's ability to finely control them, what is the purpose of stacked injectors?
Do you need more fuel than 6x 2,000cc injectors can provide at 5-6bar of pressure?
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
I do however realize ( as stated) things have improved greatly since some of RUFs early work. All one have to do is study some of the exquisite projects on this site...Apart from that, I dont know crap about, what I am talking about ![]() Nice to see you got some time to spend on the forum again
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Yup, but not picking on you or anything. :-)
The old-school stacked injectors looked cool, and solved the problem when really large injectors were not available. Who was making 600+hp back then in a road car? Supercars had 450hp! Just as a point of reference: a 3.8L Twin Turbo can idle perfectly smooth and at a clean 15:1 at 850-900rpm with modern 2,000cc injectors.
needs new tires. Again.
This looks like a fantastic solution. I'll be watching!
'87 928S4 5spd - Owner '85 930 EURO - Caretaker |
Any news on these Injector Blocks? I sent Jamie an email about 2 weeks ago no response.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
He left for Germany IIRC on Monday. I believe he will be back next week.
