The nuts holding the case halves together look like regular 8x1.25mm nuts. The original case half nuts are the self locking all steel ones where the rounded off top edge is squished together a little to make friction on the threads once the nut is threaded all the way on the stud. I've heard them called "prevailing torque" lock nuts.
I've seen nylocks used there too. Hopefully the ones you have on there will not eventually vibrate loose. Maybe they were installed with loctite so that should work too. Otherwise you could remove one nut at a time and replace it with a prevailing torque or nylock nut for peace of mind and for it to look correct. Good luck with it! |
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
They're probably installed with a drop of red loctite on the threads then.
Race mechanics and aircraft mechanics use red loctite or safety wire through little holes drilled in the nuts. You don't want to loose a race or crash a plane because a nut came loose
^ Tru Dat!
Going down a game trail on the slippery slope: decided AAR is a stupid design, so replaced it with a factory 964 turbo IACV. The upshot is no more bu!!$h¡t idle weirdness.
Got the 964 turbo IACV working today. It is just amazing what a luxury a dynamic and responsive idle controller is when you can take temp and throttle position into account.
Yes!
And it'll be that much better again when you update those silly injectors! ;-)
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Do me a favor. Show me a pic of the most stock looking EFI install you've seen.
I would rather be driving
Your worried about idle and you apparently have not even turned up the boost to a normal level. Where are your priorities?
...and I agree 100% with Chris.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
And I can't believe you used the word "Luxury" in reference to a 930.
You're all colluding against me. I'm wise to your tricks.
Banned
I'll come clean. I like metal pipes to my fuel injectors. MFI ruined me.
Banned
I'm right there with ya' about liking the look of the dinosaur-tech system. I've got a truck with an old school, International diesel engine that has MFI - always liked how it looks, too. |
We're also doing FrankenCIS right now on the targa, so will have first hand experience on that very shortly. That experience will inform how we proceed with fueling on the 930.
![]() Just kidding, this is more OE looking. Doesn't have your metal fuel lines to all 6 injectors, through.
I'm starting to grow weary of Electromotive. Their faulty coil packs fry a friends motor with no recourse. Then this week, my TPS won't post to the CPU, so we upgrade the firmware and voila, the TPS works. The problem? The knock sensors have stopped posting the to CPU. After I went to all the trouble of swapping out the Bosch knock sensors (didn't work) for GM.
WHAT THE FCUK
Problem seems to be solved with the knock sensors - a mis-dialed parameter was making the knock sensors shut off at 900 RPM, soooo...that resolved, I drove the car today for the first time on full boost. My impressions are best summarized by:
This was the car, now idling as smoothly as a Hyundai, with a smooth drone of beautiful, Zorky goodness to set the mood: The AFRs are little lean at idle and before fuel dump from the delay solenoid, but that will be resolved tomorrow. Bottom line: this is the fastest car I have ever been in and has exceeded all expectations in terms of speed and character. And it isn't even tuned yet. Happy as a clam:
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by Matt at Pelican Parts; 10-19-2023 at 07:56 AM.. |
Banned
sweet - sounds good
upper right bank valves sound a tick loose? (pun intended lol) next up: ride height 8-) |
^ just adjusted. Will listen more closely.
