3 restos WIP = psycho
The drama never ends. My injector blocks went into the parts washer...and didn't make it out. Apparently they fell apart under the strain. I can only guess that the years of heat cycles destabilized them enough that the solvent in the washer, coupled with heat and agitation, was too much. Ordered another set from Pelican, as I'm determined to complete my little injector block experiment.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
turblocks
I have a used set of those somewhere at the bottom of the stash pile. If you need them to experiment with...they are yours. regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Perchance I do, good sir. See you Tuesday?
When finished can you post KW/HP power of your engine if possible
Im doing some numbers on before and after 930 engine work Can you tell which is your engine when stock (going by your VIN) 180KW or 195KW ? This stuff is good to note and gives good figures for different type of builds and outcomes
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
Will do for sure
blocks
I'll will be there!
al
More "make it right" bits coming in via fellow Pelicans...
Looks good Kenik. I have one of those sitting on the shelf as well, just waiting for my car to get back.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Yes, I'm a sick f#©k...just received these little items:
![]() ![]() Thermal Reactors will NOT be going on the car...they will persist as wall art, attached to the stock heat exchangers and 3LDZ turbo. The decals, on the other hand WILL go on the car. I am a sucker for funky factory graphics.
Love the ol'skool turbo graphic.....that'll look cool over the sienna / sahara
Cheers DW |
The 16 x 7/9 930 Fuchs are on. Will paint them later...
Bridgestone RE-11 tires. ![]()
where did you get the decals?
VintageExcellence.com |
![]() ![]() LOL.
So when this thing is running again are you just going to drive it directly to the paint shop or enjoy it for a bit?
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
Enjoy it. Plus I'll be doing all the prime and prep myself.
I would rather be driving
decals yes! exhaust logs. NO!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Exhaust logs are just wall art.
Aircooled Breakfast
SWAG
I really wanted to make up some elaborate story about the VIN sequence and corresponding production date falling in line with pigment delivery specific to that color at the Lesonal plant... It's a beautiful color - congrats... |
Heads, Rods and Cylinders arrived over the weekend. Now we just need to mic the rods, choose the right rod bearings and the build can begin. Getting close.
Once it starts, I'll make sure to load lots of pics.
