Yay!
My car is back at Bernie's keeping yours company again.
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
3 restos WIP = psycho
I love it when a plan takes shape.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 09-23-2014 at 08:06 PM.. |
Tell us about those pistons!
RGruppe #180 So many cars.. so little time!! |
The pistons are your basic 98mm JE turbo piston. 8.5:1 CR and have had the skirts coated by Calico. I was going to have them fully coated, but my mechanic said just do the skirts, taking into consideration the success he's had with all of the 935s he's rebuilt over the last 40 years.
Heads and pistons are getting CCed today. I'm guessing the final CR comes in closer the 8:1 than 8.5:1, given the pocket for the second plug. Cylinders just came back from boring and replating, too. Also, notice the boss that was drilled and tapped into the heads for the 993 knock sensor bar (bottom pic). I am loving the security of knowing that I'll have knock control to back out timing and boost, if needed. More pics: ![]() ![]()
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Curios since you were boring and replanting cylinders why you didn't move to full fin? The 993 knock sensor bar is a very nice item to have w/EFI nice call
I'm keeping the CIS, even though I'll be using a Tec3R. No one said you have to use the fueling portion of the ECU.
Ahh this is true, assumption on my part was efi based on use of tec3r. Although yes it does offer other uses, without fueling portion.
Yes, and nor did I.. although I thought that may be where you were head, thanks for confirming. I would think it to be a lot more accurate/efficient and manageable than some of the earlier "extra" = 7th injector solutions. How many of those have we pulled off these cars?
All conjecture at this point. I have to get the car running first!
So it begins...we have bearings, crank and rods assembled.
Progress continues, but hit a minor snag with the cams...the cams just weren't quite up to snuff with the build quality and spec anymore. When this was initially going to be a bang-bang reseal, I wasn't too concerned with the minor peripheral pitting on the DC15 cams. But since I've decided to go all the way, revisiting the cams was a must once I got another look at them.
So, I sent a spare set of 993SS cams out to Dougherty to have the oil pump drive added - I expect them back next week. Let's just say the "boot in the back" character of this car is going to be something...and the K27-7006 isn't quite enough turbo to take full advantage of the cams. We can address the turbo later. ![]() BTW, check out the 993 knock sensor bars! Obligatory pics: ![]() ![]()
Finally managed to get some photos of the Ruf speedlines you sold me
Kenik. I'm liking the look.....it's a bolder look, less delicate look than the standard 16" Fuchs, but I'm happy! I'm also enjoying living the rebuild vicariously though your posts. Looking forward to seeing you latest ol' girl on the road. ![]()
No air deflector plates across the tops of the cylinders?
They look even better down under!
Not on factory 97mm "bald" cylinders.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Updates?
Waiting for cams... :P
No longer waiting for cams... Tracking number in hand and we are back on track!
Make me a deal on that now worthless K27......
