16Volt's Avatar
Yay!
My car is back at Bernie's keeping yours company again.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 09-22-2014, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
3 restos WIP = psycho
kenikh's Avatar
I love it when a plan takes shape.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-23-2014, 08:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
onboost's Avatar
Tell us about those pistons!
RGruppe #180
Old 09-24-2014, 06:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
kenikh's Avatar
The pistons are your basic 98mm JE turbo piston. 8.5:1 CR and have had the skirts coated by Calico. I was going to have them fully coated, but my mechanic said just do the skirts, taking into consideration the success he's had with all of the 935s he's rebuilt over the last 40 years.
Heads and pistons are getting CCed today. I'm guessing the final CR comes in closer the 8:1 than 8.5:1, given the pocket for the second plug. Cylinders just came back from boring and replating, too.
Also, notice the boss that was drilled and tapped into the heads for the 993 knock sensor bar (bottom pic). I am loving the security of knowing that I'll have knock control to back out timing and boost, if needed.
More pics:
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-24-2014, 12:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
onboost's Avatar
Originally Posted by kenikh View Post
The pistons are your basic 98mm JE turbo piston. 8.5:1 CR and have had the skirts coated by Calico. .
I thought they may be JE, and was wondering if you went 8.0:1 or 8.5.. nice!
Curios since you were boring and replanting cylinders why you didn't move to full fin?
The 993 knock sensor bar is a very nice item to have w/EFI nice call
RGruppe #180
Old 09-25-2014, 09:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
kenikh's Avatar
Definitely wanted better off the line throttle response. Even an SC feels a little soft to me, so every little bit helps.
I wanted to keep the motor looking original and all of the data points I've gotten from those with decades of experience is that full fin really doesn't impart a quantifiable benefit.
Who said anything about EFI? I'm keeping the CIS, even though I'll be using a Tec3R. No one said you have to use the fueling portion of the ECU.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-25-2014, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
onboost's Avatar
I Who said anything about EFI? I'm keeping the CIS, even though I'll be using a Tec3R. No one said you have to use the fueling portion of the ECU.
Ahh this is true, assumption on my part was efi based on use of tec3r. Although yes it does offer other uses, without fueling portion.
RGruppe #180
Old 09-25-2014, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
kenikh's Avatar
No one ever said that the EFI component couldn't be manifested through a single injector for wideband keyed fuel trim adjustment/enrichment...but that's crazy talk.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-25-2014, 10:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
onboost's Avatar
Yes, and nor did I.. although I thought that may be where you were head, thanks for confirming. I would think it to be a lot more accurate/efficient and manageable than some of the earlier "extra" = 7th injector solutions. How many of those have we pulled off these cars?
RGruppe #180
Old 09-25-2014, 10:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
kenikh's Avatar
I'm a long way from actually considering doing this, as i don't think I'll ever build this motor into something that will need more fuel than CIS can provide. That said, a single injector just down stream the throttle body and hidden from outside eyes could possibly be used to sharpen throttle response of the admittedly lazy CIS system.
All conjecture at this point. I have to get the car running first!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-25-2014, 10:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
kenikh's Avatar
So it begins...we have bearings, crank and rods assembled.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-01-2014, 09:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
kenikh's Avatar
Progress continues, but hit a minor snag with the cams...the cams just weren't quite up to snuff with the build quality and spec anymore. When this was initially going to be a bang-bang reseal, I wasn't too concerned with the minor peripheral pitting on the DC15 cams. But since I've decided to go all the way, revisiting the cams was a must once I got another look at them.
So, I sent a spare set of 993SS cams out to Dougherty to have the oil pump drive added - I expect them back next week. Let's just say the "boot in the back" character of this car is going to be something...and the K27-7006 isn't quite enough turbo to take full advantage of the cams. We can address the turbo later.
BTW, check out the 993 knock sensor bars!
Obligatory pics:
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-07-2014, 05:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Finally managed to get some photos of the Ruf speedlines you sold me
Kenik. I'm liking the look.....it's a bolder look, less delicate look than the standard 16" Fuchs, but I'm happy!
I'm also enjoying living the rebuild vicariously though your posts. Looking forward to seeing you latest ol' girl on the road.
Old 10-11-2014, 02:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
No air deflector plates across the tops of the cylinders?
Old 10-11-2014, 04:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
kenikh's Avatar
They look even better down under!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-11-2014, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
TurboKraft's Avatar
Not on factory 97mm "bald" cylinders.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-11-2014, 08:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
16Volt's Avatar
Updates?
Old 10-20-2014, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
kenikh's Avatar
Waiting for cams... :P
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-20-2014, 05:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
kenikh's Avatar
No longer waiting for cams... Tracking number in hand and we are back on track!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-29-2014, 03:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
16Volt's Avatar
Make me a deal on that now worthless K27......
Old 10-31-2014, 09:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
