Need 930 3.0 Intake System
I am looking for a early 930 Intakesystem with the Bosche valve on the side.
Please let me know if you have one or know one for sale.
I need it for a 75 Turbo
Steven
Looking for my Dream Car.
66/69/73 S - 75/76/77/78/79 turbo
75/76 Carrera - 2016GT3RS
PCA MEMBER
911 Registry Member
Old 11-22-2014, 03:34 PM
copbait73's Avatar
I have intake manifold, recirc. valve and aircleaner assy. Not sure about the throttle body and metering assy, WUR. Etc.
I'll check what is available.
Old 11-22-2014, 07:08 PM
Crotchety Old Bastard
RarlyL8's Avatar
I probably have the WUR and FD if you don't.
Old 11-22-2014, 10:12 PM
Chain fence eating turbo
Didn't "Robbbyg" remove his and put a 3.3 one on?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-23-2014, 06:49 AM
at the Air flow meter is on the right side a Bosch Valve, so this is what i need.
Thanks for your response, hope somebody have one in the storage.
Greetings
PCA MEMBER
911 Registry Member
Old 11-23-2014, 10:10 AM
copbait73's Avatar
Greetings
I'm confused, do you need one of the small plastic re circulation valves typically used with a custom inter cooler install?
Old 11-23-2014, 12:32 PM
Sorry.
Here are some pics from the PArt, maybe this helps
PCA MEMBER
911 Registry Member
Old 11-23-2014, 01:07 PM
RarlyL8's Avatar
What is the Bosch part number? I have a bunch of those from 3.3L engines, may have one from a 3.0L in the mix.
Old 11-23-2014, 01:29 PM
I have only the Porsche Nr. 930 110 115 01 or 930 110 805 00
But is from a 3.0 L not 3.3
PCA MEMBER
911 Registry Member
Old 11-23-2014, 01:58 PM
RarlyL8's Avatar
Bosch number for the 3.3L is 0.438.120.085
Don't know what it is for the 3.0L but it can be found on the metal tag.
Old 11-23-2014, 07:39 PM
What is #2 in this diagram? The thing sticking out below the fuel distributor.
I've never seen that before.
[/QUOTE]
Old 11-23-2014, 07:58 PM
Bosch # for the 3.0L is 0.438.120.024
1969 911T Targa (project)
1970 911T
1976 930 Turbo Carrera
1979 930 Turbo (sold)
1986 944 NA (1st P car)
Old 11-25-2014, 12:57 AM
lite75's Avatar
That's a 75 only part with the solenoid on it like that, that's what they used before the auxiliary air regulator.
75 930, 76 930, 83 SC EFI turbo
Old 11-25-2014, 06:15 AM
Ingenieur
Are you sure? It looks that would hit the air filter housing on any 930. Also, how does it add air? Doesn't look like air goes into it or out of it.
Old 11-26-2014, 02:17 PM
lite75's Avatar
Yes, I have that on my 75, it pushes the fuel metering plate down about 1/8" when the solenoid is powered.
Old 11-26-2014, 02:31 PM
RarlyL8's Avatar
The '76 housing has a provision for the solenoid but it is not mounted. My guess is the manual throttle that is next to the e-brake did the job just fine.
Old 11-26-2014, 05:18 PM
Ingenieur
Thanks. I have never seen a 1975 930. If you want to post some engine pics, I'm sure there are a lot of people here that would be interested in seeing the technology on such an early 930.
Old 11-28-2014, 07:04 PM
Got one today so thanks for the help.
Pics from an early engine will be great and helpfull
PCA MEMBER
911 Registry Member
Old 11-29-2014, 12:51 PM
Also i am looking for this Part
Porsche No 930 110 150 4R
And here a Picture from the Air meter i bought
And the Bosch no.
PCA MEMBER
911 Registry Member
Old 11-30-2014, 01:35 AM
Also looking for
intake manifold Porsche No 930 110 031 02 or 2R
PCA MEMBER
911 Registry Member
Old 11-30-2014, 01:39 AM
